Portsdown 4
Capabilities
  • Control of a Pluto, DATV Express, ADF4351 and Elcom Microwave Source using the Portsdown 4 Signal Generator.
Portsdown 4 GPIO connections
Due to a reassignment of the GPIO pins on Portsdown 4, the connections are different to previous generations of Portsdown.
Powering the Pluto
Pluto Capabilities
FAQ
cd /home/pi
chmod +x /home/pi/update.sh
./update.sh
More information
