Portsdown 4
Capabilities
  • Control of a Pluto, DATV Express, ADF4351 and Elcom Microwave Source using the Portsdown 4 Signal Generator.
Portsdown 4 GPIO connections
Due to a reassignment of the GPIO pins on Portsdown 4, the connections are different to previous generations of Portsdown.
There are 2 GPIO pins that have changed for the RPi 4. One drives the ADF4351 (was on 27, now pin 33) which you will not be using, the other is the Band LSB (or D0) this has moved from pin 28 to pin 32.
Pin 32 is available on the GPIO breakout board as the "I" pin which is pin 2 on J03. More details here: images/2/27/PORTSDOWN_INTERFACE_SCH.pdf
Powering the Pluto
Pluto Capabilities
FAQ
cd /home/pi
chmod +x /home/pi/update.sh
./update.sh
More information
