Portsdown 4
Revision as of 08:56, 29 November 2020 by G8GTZ (talk | contribs)
  • Raspberry Pi4 2Gb model
  • 7" touch screen
  • 16Gb SD card
  • Adalm Pluto
This will give you a basic DATV transmit system from 70MHz to 6GHz and can be easily upgraded to include the Langstone microwave NB transceiver!
Capabilities
  • Control of a Pluto, DATV Express, ADF4351 and Elcom Microwave Source using the Portsdown 4 Signal Generator.
Portsdown 4 GPIO connections
There are 2 GPIO pins that have changed for the RPi 4. One drives the ADF4351 (was on 27, now pin 33) which you will not be using, the other is the Band LSB (or D0) this has moved from pin 28 to pin 32.
Pin 32 is available on the GPIO breakout board as the "I" pin which is pin 2 on J03. More details here: images/2/27/PORTSDOWN_INTERFACE_SCH.pdf
Powering the Pluto
Pluto Capabilities
FAQ
cd /home/pi
chmod +x /home/pi/update.sh
./update.sh
More information
