Portsdown 4
Revision as of 14:51, 7 February 2021 by G8GTZ (talk | contribs) (→Hardware)
  • Raspberry Pi4 2Gb model
  • 7" touch screen
  • 16Gb SD card
  • Adalm Pluto
This will give you a basic DATV transmit system from 70MHz to 6GHz and can be easily upgraded to include the Langstone microwave NB transceiver!
With the addition of a MiniTiouner USB receiver [[1]], you will have a full spec DATV transceiver.
Capabilities
  • Control of a Pluto, DATV Express, ADF4351 and Elcom Microwave Source using the Portsdown 4 Signal Generator.
Portsdown 4 versus Portsdown 2020
Plus
Boots faster, Pluto compatible (with limitations), updated Sig Gen (works with Pluto, Elcom and ADF5355). Portsdown4 is the platform where all new developments, such as Knucker, will happen.
Minus
7 inch screen only. No ugly mode, Portsdown F-M mode or DTX-1 mode. Band switching on different pins.
Hardware build
With a couple of exceptions, the Portsdown 2020 uses the same hardware as the Portsdown 2019 - see this wiki page for more details.
Portsdown 4 GPIO connections
The other changed pin is the LE line for the ADF4351 (was on 27, now pin 33) which is only used if you are using an ADF4351 for the Portsdown Signal Generator.  So, generally no need to worry about this one. This isn't true if your Portsdown has an attenuator card fitted! Move the LE wire with its 1 K ohm resistor to the Q terminal.
Powering the Pluto
Pluto Capabilities
FAQ
cd /home/pi
chmod +x /home/pi/update.sh
./update.sh
More information
