New builders are recommended to build a Portsdown 4 which, when used with a Adalm Pluto, is integrated with the Langstone Microwave transceiver software enabling an advanced multimode narrow band and DATV transceiver covering 70Mhz to 6GHz for under £350.
Outline specification
System overview
Touch screen control
Depending on version (see below) the output from the RPi is connected to one of the following units. A BATC Filter Modulator board, a DATV Express Board, a LimeSDR (Mini or USB) or an Adalm Pluto, which modulates the RF carrier and produces the DVB-S or DVB-S2 DATV signal.
Audio and video inputs
Portsdown DATV receiver
The received signal is displayed on the 7" touch screen but is also available as a UDP output on the network enabling it to be viewed on a larger PC using VLC or a similar software.
Portsdown Evolution
Portsdown 4
The latest version of the Portsdown is the Portsdown 4. This uses the Raspios Buster operating system on a Raspberry Pi 4 with a 7 inch screen and a LimeSDR or ALALM Pluto. Unlike the previous version changes, it does not maintain hardware compatibility with the classic (filter-modulator) Portsdown.
Portsdown 2020 Buster
The current in-use version of the Portsdown is Buster 2020 - Portsdown 2020. This introduces support for the LimeDVB firmware on the LimeSDR Mini and also supports the use of standard firmware on the LimeSDR USB and the LimeNET Micro.
Portsdown 2019 Stretch
Portsdown 2018 Classic
Technical Index
