Portsdown 4
Revision as of 11:05, 28 June 2021 by G8GTZ (talk | contribs)
It will drive a Pluto SDR, the LimeSDR (tested with the Mini, but probably Lime SDR USB as well)and the DATV Express board (DVB-S only).
  • Raspberry Pi4 2GB model
  • 7" touch screen
  • 8, 16 or 32 GB SD card
  • Adalm Pluto or Lime SDRmini
This will give you a basic DATV transmit system from 70 MHz to 3.4 GHz and, if you are using the Pluto, can be easily upgraded to include the Langstone microwave NB transceiver!
With the addition of a MiniTiouner USB receiver [[1]], you will have a full spec DVB-S/S2 DATV transceiver. DVB-T transmit capability is now included, and the Knucker Tuner can be used with Portsdown 4 for DVB-T receive.
Capabilities
  • DVB-T (H264 only) transmissions from a LimeSDR Mini connected by USB
  • DVB-S, DVB-S2 and DVB-T (H264 only) transmissions from a Pluto SDR connected by USB
  • Streaming to the BATC Streamer using the Raspberry Pi Camera or EasyCap composite video capture device as a source
  • Reception and display of DVB-T and DVB-T2 (MPEG-2, H264 and H265) signals received by a BATC Knucker tuner connected by USB.
  • Control of a Pluto, LimeSDR Mini, DATV Express, ADF4351, Elcom and SLO Microwave Source using the Portsdown 4 Signal Generator.
  • Basic spectrum display of band occupancy using the included "Portsdown Band Viewer" and a LimeSDR Mini.
Currently not everything is working, so please have patience - check the BATC forum for latest release info https://forum.batc.org.uk/viewforum.php?f=103
Hardware build
With a couple of exceptions, the Portsdown 2020 uses the same hardware as the Portsdown 2019 - see this wiki page on the 2019 hardware set for more details.
Portsdown 4 GPIO connections
The other changed pin is the LE line for the ADF4351 (was on 27, now pin 33) which is only used if you are using an ADF4351 for the Portsdown Signal Generator.  So, generally no need to worry about this one. This isn't true if your Portsdown has an attenuator card fitted! Move the LE wire with its 1 K ohm resistor to the Q terminal.
Powering the Pluto
You MUST start with a fresh build of Raspios Buster Lite (NOT the older Raspbian) on an SD Card of 8 GB or greater, so you will need to rebuild any previous Langstone or Portsdown A27 card.
Pluto Capabilities
FAQ
cd /home/pi
chmod +x /home/pi/update.sh
./update.sh
  • I have built my Portsdown 4 but the screen is upside down. How can I get it the right way up?
More information
