Portsdown 4
The Portsdown 4 transceiver software has been specifically designed to be used with the Raspberry Pi 4 and the official Raspberry Pi 7 inch touchscreen. It will drive a Pluto SDR or the LimeSDR and the DATV Express board (DVB-S only).
  • Raspberry Pi4 2GB model
  • 7" touch screen
  • 8, 16 or 32 GB SD card
  • Adalm Pluto or Lime SDRmini
This will give you a DVB-S2 and DVB-T DATV transmit system from 30 to 3500 MHz when using a Lime SDR and 50MHz to 4100 MHz with the Pluto.
With the addition of a MiniTiouner USB receiver [[1]], you will have a full spec DVB-S/S2 DATV transceiver.
With the addition of the Knucker USB tuner you will also have DVB-T receive capabilities.
Capabilities
Portsdown 4 transmit and receive capabilities:
  • DVB-S, DVB-S2 and DVB-T (H264 only) transmissions from a Pluto SDR connected by USB
  • DVB-S, DVB-S2 and DVB-T (MPEG-2 and H264) transmissions from a LimeSDR Mini or LimeSDR USB
  • Streaming to the BATC Streamer using the Raspberry Pi Camera or EasyCap composite video capture device as a source
When a MiniTiouner USB receiver is connected via USB:
When a BATC Knucker USB tuner connected by USB:
  • Reception and display of DVB-T and DVB-T2 (MPEG-2, H264 and H265) signals
Portsdown test and alignment aids
  • Basic spectrum display of band occupancy using the "Portsdown Band Viewer" - requires a LimeSDR Mini to be connected.
No other models of Raspberry Pi or touchscreen are planned to be supported in the near future.
Portsdown 4 GPIO connections
Powering the Pluto
Portsdown hardware
Full details of the Portsdown hardware are available here.
You MUST start with a fresh build of Raspios Buster Lite (NOT the older Raspbian) on an SD Card of 8 GB or greater, so you will need to rebuild any previous Langstone or Portsdown A27 card.
Langstone Narrow band transceiver
Pluto Capabilities
The Portsdown 4 support for the Pluto SDR is still undewr development and there are some limitations on functionality as described here Portsdown 4 Pluto.
FAQ
cd /home/pi
chmod +x /home/pi/update.sh
./update.sh
  • I have built my Portsdown 4 but the screen is upside down. How can I get it the right way up?
More information
