The Portsdown DATV transceiver project provides an easy way to “get on air” with Digital ATV at a relatively low cost covering all of the commonly used DATV modes enabling it to be used for cross town QSOs, accessing ATV repeaters and for working the DX using Reduced bandwidth (RB-TV) modes.
New builders are recommended to build a Portsdown 4 which, when used with an Adalm Pluto, is integrated with the Langstone Microwave transceiver software enabling an advanced multimode narrowband and DATV transceiver covering 70Mhz to 6GHz for under £350. Full details on the Portsdown 4 are on this wiki page.
Outline specification
System overview
  • BATC Filter Modulator board - first used in Portsdown 2018 Classic but no longer available
  • DATV Express Board - first used in Portsdown 2018 Classic but no longer available
  • LimeSDR (Mini or USB)
  • Adalm Pluto
Audio and video inputs
The Portsdown transmitter will take audio and video inputs from the RPi camera, an EasyCap composite video USB dongle, C920 webcam and a USB sound card / dongle - all these are readily available from ebay and Amazon.
Portsdown DATV receiver
For more details on DATV receptions see https://wiki.batc.org.uk/DVB-S/S2_Reception
Portsdown Test Equipment
The Portsdown 4 includes some test equipment features.
The Signal Generator is decribed here: Portsdown_4_Signal_Generator.
The Band Viewer is described here: Portsdown_Band_Viewer.
The Power Meter is described in CQ-TV 273.
The Noise Figure Meter is still under development but is described here Portsdown NF Meter
Portsdown Hardware
Technical Index
Portsdown Evolution
Portsdown 4
The latest version of the Portsdown is the Portsdown 4. This uses the Raspios Buster operating system on a Raspberry Pi 4 with a 7 inch screen and a LimeSDR or ADALM Pluto. Unlike the previous version changes, it does not maintain hardware compatibility with the classic (filter-modulator) Portsdown.
Portsdown 2020 Buster
The Portsdown 2020 is Rpi3 based running Buster operating system - Portsdown 2020. This introduces support for the LimeDVB firmware on the LimeSDR Mini and also supports the use of standard firmware on the LimeSDR USB and the LimeNET Micro.
Portsdown 2019 Stretch
