Repeater Controller
Revision as of 18:44, 13 February 2022 by G8GTZ (talk | contribs) (→Customisation)
Typical operation
The BATC repeater controller will control either a single or multiple video switchers either by InfraRed or GPIO pins and will generate a carousel of scenes.
Carousel
Valid signal input
Ident signal
DTMF control
Power saving
Hardware control
  • I2C devices such as the McGuffin series Audio and video switches and relay boards.
The IR and I2C commands for each input are set in the config file.
Configuring IR Switching
The IR codes for the HDMI switches used on your repeater will need to entered in the configuration file.
Customisation
Some configuration can be done using the SSH menu - for more details see the Repeater Controller configuration page.
Some real-time control is possible using the ssh Console Menu (type menu at the ssh command prompt), but the configuration file is too comprehensive for all the functions to be edited from a simple menu.
Most advanced customisation will require the careful editing of the text file /home/pi/atv-rptr/config/repeater_config.txt;
GPIO Connections
The repeater controller will switch a GPIO output to indicate one of up to eight receiver inputs has been activated.
This can be used to control an external video switcher but note care MUST be taken to buffer the 3.3 volt logic levels used on the Raspberry Pi GPIO pins.
Switching Logic
Project status
Jan 22 - Aplha release for testing
Feb 10th 2022 An early Beta version of the software (not yet ready for use, but good enough for shack-based testing) can be found here: https://github.com/BritishAmateurTelevisionClub/atv-rptr
