Repeater Controller
The BATC ATV Repeater Controller uses a Raspberry Pi 4 as a fully-featured, but simple-to-implement, ATV repeater controller. The design is intended to be used with an HDMI Video switch, but can also be used with older composite video designs.
Every repeater is different and this is designed as a core logic that can be used as the basis for an ATV repeater. The design is flexible with a large number of parameters in a text editable config file so that users can configure it to meet their own needs.
Typical operation
Carousel
Valid signal input
Ident signal
DTMF control
Power saving
Hardware control
  • I2C devices such as the Audio and video switches and relay boards designed for GB3SQ.
The IR and I2C commands for each input are set in the config file.
Configuring IR Switching
The IR codes for the HDMI switches used on your repeater will need to entered in the configuration file.
Customisation
GPIO Connections
Switching Logic
Project status
Jan 22 - Aplha release for testing
Feb 10th 2022 An early Beta version of the software (not yet ready for use, but good enough for shack-based testing) can be found here: https://github.com/BritishAmateurTelevisionClub/atv-rptr
