Repeater Controller
Revision as of 16:19, 15 February 2022 by G8GTZ (talk | contribs) (→DTMF control)
The BATC ATV Repeater Controller uses a Raspberry Pi 4 as a fully-featured, but simple-to-implement, ATV repeater controller. The design is intended to be used with an HDMI Video switch, but can also be used with older composite video designs.
Every repeater is different and the controller is designed as a core logic that can be used as the basis for an ATV repeater. The design is flexible with a large number of parameters in a text editable config file so that users can configure it to meet their own needs.
Typical operation
Carousel
The carousel can be configured to show up to 99 scenes which can be .jpg or .png images, an input on the video switcher for example mast cam, or a video file (in future release). The still images are read each time before display so can be regularly updated by an external source.
Valid signal input
Ident signal
DTMF control
Power saving
Hardware control
  • I2C. Initial support for the Audio switch designed for GB3SQ. Future releases may support I2C video switches and relay boards.
The IR and I2C commands for each input are set in the config file.
Configuring IR Switching
Customisation
GPIO Connections
Switching Logic
Project status
Jan 22 - Aplha release for testing
Feb 10th 2022 An early Beta version of the software (not yet ready for use, but good enough for shack-based testing) can be found here: https://github.com/BritishAmateurTelevisionClub/atv-rptr
