Repeater Controller
The BATC ATV Repeater Controller uses a Raspberry Pi 4 as a fully-featured, but simple-to-implement, ATV repeater controller. The design is intended to be used with an HDMI Video switch, but can also be used with older composite video designs.
Every repeater is different and the controller is designed as a core logic that can be used as the basis for an ATV repeater. The design is flexible with a large number of parameters in a text editable config file so that users can configure it to meet their own needs.
Typical operation
Carousel
The carousel can be configured to show up to 99 scenes which are played out from the controller RPi and can be .jpg or .png images, an input on the video switcher for example mast cam, or a video file (in future release). The still images are read each time before display so can be regularly updated by an external source.
Valid signal input
Ident signal
The controller RPi also generates images for the K sequence and input identification. A video and/or audio ident can be generated at an interval set in the config file.
DTMF control
Power saving
Hardware control
- Video switches via IR transmitters (note up to 2 IR transmitters can be configured separately allowing multiple video switches to be cascaded).
- Video switchers via hardware lines driven from the RPi GPIO lines (note 3.3v logic output)
- I2C. Initial support for the Audio switch designed for GB3SQ. Future releases may support I2C video switches and relay boards.
The IR and I2C commands for each input are set in the config file.
Configuring IR Switching
Customisation
DTMF control
The following functions can be changed using DTMF commands - actual command sequence is entirely flexible and set in the config file. It is recommended that some command sequences such as shut down are publicly available and have been grouped in the example config file (see Repeater Controller configurationas keeper commands.
Suggested keeper functions
dtmfkeepertxoff=97350 dtmfkeepertxon=97351 dtmfkeeperreboot=97359 dtmftalkbackaudioenable=07 dtmftalkbackaudiodisable=08
dtmfstatusview=01 dtmfquadview=04 dtmfselectinput0=10 dtmfselectinput1=11 dtmfselectinput2=12 dtmfselectinput3=13 dtmfselectinput4=14 dtmfselectinput5=15 dtmfselectinput6=16 dtmfselectinput7=17
dtmfoutputs=1 dtmfgpioout1pin=15 dtmfgpioout1label=shack_light dtmfgpioout1on=31 dtmfgpioout1off=41
dtmfinputs=1 dtmfgpioin1pin=8 dtmfgpioin1label=cabinet_door
MCP23017. Max 16 lines either in or out i2cioaddress=0
i2cdtmfoutputs=1 i2cdtmfgpioout1pin=a0 i2cdtmfgpioout1label=shack_heater i2cdtmfgpioout1on=51 i2cdtmfgpioout1off=61
i2cdtmfinputs=1 i2cdtmfgpioin1pin=b0 i2cdtmfgpioin1label=cabinet_lid
GPIO Connections
Switching Logic
Project status
Jan 22 - Aplha release for testing
Feb 10th 2022 An early Beta version of the software (not yet ready for use, but good enough for shack-based testing) can be found here: https://github.com/BritishAmateurTelevisionClub/atv-rptr
