Revision as of 10:06, 18 February 2022 by G8GTZ (talk | contribs) (→‎SSH Menu)
SSH Menu
Reload
1 Behaviour
5 - Operating hours. Selection of transmit key line to be active continuously or just during a timed period to save power. If timed, select the start and stop times. Note time is set using UTC time, not local time.
8 - Half hour. If enabled, the transmitter will only be keyed in beacon mode during the first 30 minutes of every hour and not during the 2nd half hour to save power.
11 - Apply changes
12 - Return to main menu
2 Callsign
3 Inputs
10 - Apply
11 - Main Menu
4 Control
5 Update
6 Settings
1 - Reset factory defaults
3 - Main menu.
7 Diagnostics
8 Reboot
Editing the config file
Typical config file
callsign=GB3HV locator=IO91LD
Video output
vidout=hdmi1080
audiokeepalive=yes
transmitenabled=yes
beaconmode=no
transmitwhennotinuse=yes
24houroperation=yes
halfhourpowersave=no
operatingtimestart=1300
operatingtimefinish=2330
Quiet hours behaviour:
repeatduringquiethours=no
identduringquiethours=no
(available pins are 40 .....)
pttgpiopin=40
Local audio
carouselusbaudiomode=off
carouselusbaudiogain=100
DTMF repeater control
These are just example commands - see DATV repeater DTMF commands for more details
dtmfcontrol=on
dtmfaudiogain=62
dtmfactiontimeout=600
dtmfreset=00
dtmfstatusview=01
dtmfquadview=04
dtmfselectinput0=10
dtmfselectinput1=11
dtmfselectinput2=12
dtmfselectinput3=13
dtmfselectinput4=14
dtmfselectinput5=15
dtmfselectinput6=16
dtmfselectinput7=17
DTMF Keeper codes
Examples:
dtmfkeepertxoff=97350
dtmfkeepertxon=97351
Turns Tx key on / off
dtmfkeeperreboot=97359
Reboot controller
DTMF input can also be used to control external equipment via the GPIO pins
dtmfoutputs=1
dtmfgpioout1pin=8
dtmfgpioout1label=shack_light
dtmfgpioout1on=31
dtmfgpioout1off=41
dtmfinputs=1
dtmfgpioin1pin=8
dtmfgpioin1label=cabinet_door
Ident info
identinterval=900
identmediatype=jpg
identmediaduration=5
identcwaudio=on
identcwspeed=15
identcwpitch=800
identcwlevel=50
K information
kmediatype=jpg
kmediaduration=5
kmediafile=/home/pi/tmp/k.jpg
kcwaudio=on
kcwspeed=20
kcwpitch=800
kcwlevel=50
kcwfile=/home/pi/tmp/k.wav
Carousel information
carouselscenes=5
Input configuration
Show Quad is yes/no
availableinputs=4
activeinputhold=no
showquadformultipleinputs=yes
Output video switch config
outputswitchcontrol=ir
showoutputongpio=yes
outputhdmiresetcode=nec:0x17
Configure 2nd IR output
output2ndhdmicode=nec:0x08
outputhdmiquadcode=nec:0x18
input0name=Controller
output0code=nec:0x17
output0hdmiswitchpin=36
Configure input 1
input1name=Stream Input
input1prioritylevel=1
input1activegpiopin=32
output1code=nec:0x12
output1hdmiswitchpin=37
input1announcemediatype=jpg
input1announcemediaduration=3
Configure input 2
input2name=QO-100 RX
input2prioritylevel=2
input2activegpiopin=21
output2code=nec:0x59
output2hdmiswitchpin=38
input2announcemediatype=jpg
input2announcemediaduration=3
Configure input 3
input3name=3.4 GHz Ryde
input3prioritylevel=3
input3activegpiopin=18
output3code=nec:0x08
output3hdmiswitchpin=33
input3announcemediatype=jpg
input3announcemediaduration=3
Input 4 configuration
input4name=Quad View
input4prioritylevel=7
input4activegpiopin=22
output4code=nec:0x18
output4hdmiswitchpin=31
input4announcemediatype=jpg
input4announcemediaduration=3
Input 5 configuration
input5name=Mast Camera
input5prioritylevel=7
input5activegpiopin=16
output5code=2nec:0x12
output5hdmiswitchpin=29
input5announcemediatype=jpg
Input 6 configuration
input6name=Unused 6
input6prioritylevel=9
input6activegpiopin=19
output6code=2nec:0x59
output6hdmiswitchpin=23
input6announcemediatype=jpg
input6announcemediaduration=3
Input 7 configuration
input7name=Unused 7
input7prioritylevel=9
input7activegpiopin=21
output7code=2nec:0x08
output7hdmiswitchpin=24
input7announcemediatype=jpg
input7announcemediaduration=3
