Gerber Files
Revision as of 12:07, 13 July 2022 by G0MJW (talk | contribs)
Ryde Front Panel
File:Gerbers.zip
ADF4351 PIC Controller
File:adf435x.zip
DATV Repeater Audio Switch
G0MJW's Ryde board
This is like a plug in board for the PI4 that provides the 5V PSU, a cooling option and Ryde IO interface. The information is all below. There are two PSU options, only one is required. All fairly simple.
File:RydeGpioV2.zip
File:ibom.zip
G0MJW's PD4 board
TBC (after CAT22)
This is a PCB to implement a Portsdown 4 with 25 pid connector for interfacing to test equipment.
