Repeater Controller
Revision as of 19:06, 14 November 2023 by G8GKQ (talk | contribs) (→Hardware control)
The controller is intended to be used with an HDMI Video switch, but can also be used with other switchers such as an ATEM Mini or older composite video designs.
Typical operation
Carousel
  • Video files (in future release).
  • Any input on the video switcher, so can display inputs such mast cams, weather stations or Quad video displays.
The still images are read each time before display so can be regularly updated by an external source such as weather maps, propagation maps or DXspots.
Valid signal input
On receipt of a valid GPIO line signal from, for example, a Ryde receiver, the controller will, key the transmitter, play an audio beep and display an image for .5 seconds indicating which input has been activated and then switch to that input. When the receiver closes, the logic will play a "K" image and optional "K" in Morse and go back to the carousel.
Ident signal
DTMF control
Power saving
Additionally, the controller can provide time-based control of the power to the receivers and encoder/exciter so that they can be shut down outside operating hours. Two operating periods can be defined in the config file, and the equipment can also be shut down and restarted using a fron-panel button. A preceding shutdown signal is provided to allow proper shutdown of the Raspberry Pis. This power control uses the same GPIO pins as Input 7, so is only compatible with the use of 6 or less repeater inputs.
Repeater system sample builds
Hardware control
  • Video switches via IR transmitters - up to 2 IR transmitters can be configured separately allowing multiple video switches to be cascaded.
  • i2c
  • Network control of an ATEM Mini Pro
The IR, i2c and ATEM commands for each input are set in the config file.
i2c interface
The controller will support i2c video switches and relay boards in the future. I2c Interface details are here: DATV Repeater i2c Interface.
i2c audio switching
Currently, the controller only supports the i2c controlled Audio switch designed for GB3SQ.
Details of the 8 channel input audio switch PCB can be found here DATV repeater audio switch and a PCB is available from the BATC shop.
Configuring IR Switching
The IR codes for the video switches used on a repeater will need to be entered in the configuration file - see Repeater Controller configuration.
IR Transmitter Control Circuits
Here are example IR transmitter control circuits for the single and dual switch cases:
Customisation and configuration
DTMF control
GPIO Connections
  • Accepts up to 8 signal detect inputs
  • IR / I2C drive output
  • GPIO outputs to control video switchers.
  • Auxilliary equipment status monitoring inputs
  • Auxilliary equipment control outputs
The exact pins used for each function are set in the configuration file.
The Ryde signal detect line can be connected to the input pin but Care MUST be taken to buffer the 3.3 volt logic levels used on the Raspberry Pi GPIO pins.
Mains Power Control
The controller includes a number of features to reduce mains power consumption and to allow safe shutdown of Raspberry Pi based receivers and the controller itself. Full details can be found here: Repeater Controller Power Control.
Composite video input
In order to enable analogue receivers and equipment, such as mast cameras, to be connected to an HDMI switcher, BATC has developed a composite to HDMI converter.
Based on the Ryde software running on a Pi3 or Pi4, it uses a Fushicai EasyCap and provides a high-quality converter even with noisy FM video signals.
Build an SD card with the Ryde software and after updating to release 03/03/22 select Option 8 on the Settings Menu in the SSH Console Menu.
Then manually edit the file /home/pi/ryde-build/cv_config.txt where you can set audio out, 16:9/4:3 and the ident caption.
After rebooting with a Fushicai EasyCap connected, the HDMI output will show the Composite video input and carry the audio from the dongle.
Note This is not a Ryde facility, the Ryde build was just a convenient starting point for the software build.
Switching Logic
Project status
The software was put on full release at the end of March 2022.
Dec 2021 - Requirement spec agreed.
Feb 15th 2022 - Feature freeze until the first release in March
Marrch 2022 -First production release
February 2023 - Updated to include safe shutdown and receiver/exciter power switching.
Software download
The BATC controller is available for download at https://github.com/BritishAmateurTelevisionClub/atv-rptr
Please follow the instructions carefully and note the controller runs on the Buster Lite OS and not Bullseye.
Depending upon demand we may sell preprogrammed SD cards in the BATC shop.
Future requirements
  • VLC Carousel Play of videos
  • Full implementation of i2c accessory switch operation (Entries exist in config file, but not yet coded)
  • Composite video output
