The Portsdown DATV transceiver project provides an easy way to “get on air” with Digital ATV at a relatively low cost covering all of the commonly used DATV modes enabling it to be used for cross town QSOs, accessing ATV repeaters and for working the DX using Reduced bandwidth (RB-TV) modes.
New builders are recommended to build a Portsdown 4 which, when used with an Adalm Pluto, is integrated with the Langstone Microwave transceiver software enabling an advanced multimode narrowband and DATV transceiver covering 70Mhz to 6GHz for under £350. Full details on the Portsdown 4 are on this wiki page.
Outline specification
System overview
The Portsdown 4 can also be controlled from a web browser (on a PC, tablet or smartphone); full details here: Portsdown 4 Web Control.
  • BATC Filter Modulator board. DVB-S only. Portsdown 2020 only.
  • DATV Express Board (no longer available). DVB-S only. Portsdown 2020 and Portsdown 4.
  • LimeSDR (Mini or USB). DVB-S and DVB-S2. Portsdown 2020 and Portsdown 4.
  • Adalm Pluto. DVB-S and DVB-S2. Portsdown 4 only.
Audio and video inputs
The Portsdown transmitter will take audio and video inputs from the RPi camera, an EasyCap composite video USB dongle, C920 webcam and a USB sound card / dongle - all these are readily available from ebay and Amazon. It will also accept an externally encoded Transport Stream from a PC or a LinkPi encoder.
Portsdown DATV receiver
On Portsdown 2020 and Portsdown 4, if you plug a MiniTuioner USB receiver hardware or a PicoTuner into the RPi USB port and select "Rx" on the top level menu, you will have access to a fully functional DVB--S/S2 DATV receiver. If used with a Knucker tuner, DVB-T transmissions can also be received.
For more details on DATV receptions see https://wiki.batc.org.uk/DVB-S/S2_Reception
Portsdown Test Equipment
The Portsdown 4 includes some very useful test equipment features including 6GHz RF signal generator, Noise figure meter, frequency sweeper and noise power meter.
See this wiki page Portsdown Test Equipment for more details.
Portsdown streamer to BATC.TV
The Portsdown can be used to stream to the BATC streamer - see https://wiki.batc.org.uk/Configuring_your_channel#Streaming_from_the_Portsdown
Meteor Viewer
The Portsdown build includes the capability to view 10 kHz of spectrum from an SDRPlay RSPdx. This capability is intended to be used to view the reflections of the GB3MBA beacon from meteors. Full details here: Portsdown MeteorView.
Portsdown Hardware
Technical Index
HDMI Repeater TX Build Instructions
The Portsdown 4 can be used with an Elgato Camlink 4K HDMI capture dongle and a LimeSDR as the basis of an all-digital repeater transmitter (see CQ-TV 277). The software setup is described here Portsdown 4 HDMI Repeater TX Card Setup.
Portsdown Evolution
Portsdown 4
The latest version of the Portsdown is the Portsdown 4. This uses the Raspios Buster legacy operating system on a Raspberry Pi 4 with a 7 inch screen and a LimeSDR or ADALM Pluto. Unlike the previous version changes, it does not maintain hardware compatibility with the classic (filter-modulator) Portsdown.
The Portsdown 4 can transmit and receive DVB-S, DVB-S2 and DVB-T. The transmit capabity requires a LimeSDR or Pluto SDR and the receve capability requires a MiniTiouner (DVB-S/S2) or Knucker Tuner (DVB-T).
New developments will be fielded in the Portsdown 4 software, and may not be back-ported to the Portsdown 2020.
Portsdown 2020 Buster
The Portsdown 2020 is Raspberry Pi 3 based running the Buster legacy operating system - Portsdown 2020. This software includes support for the LimeDVB firmware on the LimeSDR Mini and also supports the use of standard firmware on the LimeSDR USB and the LimeNET Micro.
This version will continue to be actively supported, but most new developments will be reserved for the Portsdown 4.
Portsdown 2019 Stretch
Portsdown 2018 Classic
