HAMTV from the ISS
The unit failed in 2019, and was brought back to earth for repair. It was returned to the ISS on the SpaceX SpX-30 flight on March 21st 2024 and it was hoped that it would be recommissioned by a visiting astronaut within a few weeks of its arrival. Presently, mid-July 2024, some work still needs to be completed to enable the placement of the HamTV in the Columbus module. Technically this is known as a “topology reassessment” and this may take a further three months to complete. Therefore the expected commencement of operations remains “TBD” but will not be before Autumn 2024.
HAMTV specifications
Ham Video RF Transmission
- 2369 MHz
- 2422 MHz
- 2437 MHz
Polarisation is RHCP.
DVB-S modulation
- FEC : ½
- Rolloff: 35%
TS format
- MPEG-2 Video, approx. 1 Mbits/s, PID 256
- MP2 Audio, approx 360kb/s, PID 257
- Null padding, PID 8191
- NTSC
ISS HAMTV antenna
What is HAMTV used for?
How to receive HAMTV?
* The LNA / Downconverter should placed as close as possible to the dish feed and high quality microwave cable must be used. * The upper blue-boxes option is the preferred solution for new builders. * In the blue-boxes option the line amplifier and filters are at 2.4Ghz and GOOD (not cheap) quality satellite co-ax must be used to avoid the RF level being too low at the receiver. * The satellite line amplifiers are required to ensure there is enough signal at the receiver input - these may be placed at masthead or in the shack * The filters are essential, not nice to have! * The Minitiouner V2 / Pico tuner USB receiver can be connected to EITHER a PC running OpenTuner or Minitiouner software or a Pi4 based Ryde set top box receiver.
Ground station antennas
Rotator (mechanical tracking)
- 1m dish: 8 degrees beamwidth (+/-4 degrees)
- 1.8m dish: 4.5 degrees beamwidth (+/-2.2 degrees)
Dish feeds
LNA and Pre-amp
Commercial LNA Options
- Best and most expensive: KU LNA 220240 A - 0.4dB NF, KU LNA 222 AH - 0.5dB NF
- Lower cost (relative), good performance: Minicircuits ZX60-242GLN-S+ - 0.9dB NF
Band pass Filter
Receive co-ax cable
Receive Line amplifier
Your masthead LNA/LNB MUST have enough gain to overcome your co-ax cable loss. The satellite line amplifier can be placed at masthead if needed to help overcome the feeder loss or in the shack. To hear more about the importance of noise figure and gain distribution in a DATV receive system watch https://youtu.be/lfSi7vTQK44?si=wn_wLBjxco3_RnAf
Do I need a downconverter?
Note: The MiniTiouner Mk1 PCB with a Sharp or Eardatek tuner does NOT cover 2395MHz and will require a downconverter. The Seit NIM also has better RF performance than the Sharp or Eardatek units.
Digital receivers for HAMTV
Receivers designed for DATV
USB Receiver hardware
Mark 2 MiniTiouner PCB
PicoTuner PCB
MiniTiouner Mk1 PCB
Ryde
OpenTuner
Portsdown
MiniTiouner
PC software receivers
- SDRangel https://www.sdrangel.org/
- SatDump https://www.satdump.org/
- Demonstration from Author using 2016 IQ recording: https://twitter.com/aang254/status/1771869215776985466
Receiving the Signal
Testing your system
Measuring sun noise
Portsdown DATV test system
- Connect the signal from your LNA / downconverter to the rx port on a Lime SDR or a Pluto SDR and select Menu 2 > test equipment > Noise power meter.
- In setting menu, adjust the Lime gain so that the noise floor sits at around -60dBm.
- From the main menu, select differential in the mode settings and then touch the right side of the "analogue" meter display on the main menu to set it to display -5 to +5dB.
- As you turn your antenna through the sun you should see a hump on the the time / gain display as the meter reads the level of sun noise - expect to see approximately 2dB on an average HamTV system.
The Portsdown DATV transceiver has a number of very useful RF test modes including a noise figure meter and a noise power meter. A very simple system can be built from a Raspberry Pi 4 running the free to download software and a LimeSDR or Pluto SDR - see this wiki page for a complete list
SDR continuum mode
Decoding a local signal
Playing out a local IQ file
- Connect the Portsdown to the internet and attach a LimeSDR. On Menu 1, select "Freq" and select the frequency that you want the signal to be generated on; you can use the keyboard key to enter 2395 MHz.
- Select Menu 2, File Menu, Download HamTV IQ File. Note that this is a 2 GB file which takes at least 5 minutes to download, and another 5 minutes to unzip.
- Once the file has downloaded, select Menu 2, File Menu again and then "Select IQ File". Touch the file SDRSharp_20160423_121611Z_731000000Hz_IQ.wav so that it is highlighted and press select.
- Then press "Play IQ File". The file will be played out on the frequency that you selected in the first step.
- 5Ms/s Complex Samples
- WAV (SDRsharp) format
- Please note that these were recorded on a 0.6m hand-steered dish, so the signal in the recordings will fade in and out of being decodable even with the best receiver!
Actually receiving HamTV
In the meantime - here is a webpage that shows GHY6 dish at Goonhilly https://status.ghy6.goonhilly.org/camera/ If you look to the left of the 32 metre dish you can just see a small dish. It is actually a 5 metre dish! When not otherwise in use, this is already tracking the ISS and is receiving on 2395MHz. When a DATV signal is received it will automatically appear here https://live.ariss.org/hamtv/
Social media
BATC forum
Youtube videos
Comments on this wiki page
