HAMTV from the ISS
Revision as of 19:11, 30 July 2025 by G8GTZ (talk | contribs)
The unit failed in 2019, and was brought back to earth for repair. It was returned to the ISS on the SpaceX SpX-30 flight on March 21st 2024. Unfortunately a lengthy "topology reassessment" was then required due to space issues in the Columbus module.
29th July 2025 - Following years of work by the ARISS team, the HamTV module has been successfully reinstalled and is active. No video source is currently connected so only a black screen is transmitted.
You can see live video from the ISS as received by a chain of stations using the BATC merger here https://live.ariss.org/hamtv/
HAMTV specifications
Ham Video RF Transmission
  • 2369 MHz
  • 2422 MHz
  • 2437 MHz
Polarisation is RHCP.
DVB-S modulation
  • FEC : ½
  • Rolloff: 35%
TS format
  • MPEG-2 Video, approx. 1.5 Mbits/s, PID 256
  • MP2 Audio, approx 364kb/s, PID 257
  • Null padding, PID 8191
  • NTSC
ISS HAMTV antenna
What is HAMTV used for?
It is hoped in the future that test patterns, including JPEG images, will be transmitted when the cameras are not in use.
How to receive HAMTV?
* The LNA / Downconverter should placed as close as possible to the dish feed and high quality microwave cable must be used.
* The upper blue-boxes option is the preferred solution for new builders.
* In the blue-boxes option the line amplifier and filters are at 2.4Ghz and GOOD (not cheap) quality satellite co-ax must be used to avoid the RF level being too low at the receiver.
* The satellite line amplifiers are required to ensure there is enough signal at the receiver input - these may be placed at masthead or in the shack
* The filters are essential, not nice to have!
* The Minitiouner V2 / Pico tuner USB receiver can be connected to EITHER a PC running OpenTuner or Minitiouner software or a Pi4 based Ryde set top box receiver.
Ground station antennas
Rotator (mechanical tracking)
  • 1m dish: 8 degrees beamwidth (+/-4 degrees)
  • 1.8m dish: 4.5 degrees beamwidth (+/-2.2 degrees)
Dish feeds
LNA and Pre-amp
Commercial LNA Options
Band pass Filter
Receive co-ax cable
Receive Line amplifier
Your masthead LNA/LNB MUST have enough gain to overcome your co-ax cable loss.  The satellite line amplifier can be placed at masthead if needed to help overcome the feeder loss or in the shack.  To hear more about the importance of noise figure and gain distribution in a DATV receive system watch https://youtu.be/lfSi7vTQK44?si=wn_wLBjxco3_RnAf
Do I need a downconverter?
Note: The MiniTiouner Mk1 PCB with a Sharp or Eardatek tuner does NOT cover 2395MHz and will require a downconverter.  The Serit NIM also has better RF performance than the Sharp or Eardatek units.
Digital receivers for HAMTV
Receivers designed for DATV
USB Receiver hardware
Note from 2024 the MiniTiouner has been replaced with the PicoTuner see below.
Mark 2 MiniTiouner PCB
PicoTuner PCB
MiniTiouner Mk1 PCB
Ryde
OpenTuner
For general details see this wiki page: OpenTuner
Instructions on how to set OpenTuner up for receiving HamTV (updated 30 July 2025) are here: OpenTuner for HamTV
Portsdown
MiniTiouner
PC software receivers
SDR Television software
SDRTV by Simon Brown G4ELI will NOT receive the DVB-S HAMTV signal and Simon has confirmed the capability will NOT be added to any future release.
Receiving the Signal
Testing your system
Measuring sun noise
Portsdown DATV test system
  • Connect the signal from your LNA / downconverter to the rx port on a Lime SDR or a Pluto SDR and select Menu 2 > test equipment > Noise power meter.
  • In setting menu, adjust the Lime gain so that the noise floor sits at around -60dBm.
  • From the main menu, select differential in the mode settings and then touch the right side of the "analogue" meter display on the main menu to set it to display -5 to +5dB.
  • As you turn your antenna through the sun you should see a hump on the the time / gain display as the meter reads the level of sun noise - expect to see approximately 2dB on an average HamTV system.
The Portsdown DATV transceiver has a number of very useful RF test modes including a noise figure meter and a noise power meter.  A very simple system can be built from a Raspberry Pi 4 running the free to download software and a LimeSDR or Pluto SDR - see this wiki page for a complete list
SDR continuum mode
Decoding a local signal
Playing out a local IQ file
  • Connect the Portsdown to the internet and attach a LimeSDR. On Menu 1, select "Freq" and select the frequency that you want the signal to be generated on; you can use the keyboard key to enter 2395 MHz.
  • Select Menu 2, File Menu, Download HamTV IQ File. Note that this is a 2 GB file which takes at least 5 minutes to download, and another 5 minutes to unzip.
  • Once the file has downloaded, select Menu 2, File Menu again and then "Select IQ File". Touch the file SDRSharp_20160423_121611Z_731000000Hz_IQ.wav so that it is highlighted and press select.
  • Then press "Play IQ File". The file will be played out on the frequency that you selected in the first step.
  • 5Ms/s Complex Samples
  • WAV (SDRsharp) format
  • Please note that these were recorded on a 0.6m hand-steered dish, so the signal in the recordings will fade in and out of being decodable even with the best receiver!
Actually receiving HamTV
Social media
BATC forum
Youtube videos
Comments on this wiki page
