Revision as of 19:32, 12 September 2026 by G8GKQ (talk | contribs) (→Audio and video inputs)
The Portsdown DATV transceiver project provides an easy way to “get on air” with Digital ATV at a relatively low cost covering all of the commonly used DATV modes enabling it to be used for cross town QSOs, accessing ATV repeaters and for working the DX using Reduced bandwidth (RB-TV) modes. It also includes some test equipment software.
The aim of the Portsdown project is to enable an amateur radio operator with little or no knowledge of Digital ATV to construct the hardware elements, load and configure the software and use the system to send and receive live Digital ATV signals across town on his existing aerials.
New builders are recommended to build a Portsdown 4 which, when used with an Adalm Pluto, is integrated with the Langstone Microwave transceiver software enabling an advanced multimode narrowband and DATV transceiver covering 70Mhz to 6GHz for under £350. Full details on the Portsdown 4 are on this wiki page. Note that the Portsdown 4 is more capable than the Portsdown 5.
The Portsdown 4 will ONLY work on a Raspberry Pi 4. It will not work on a Raspberry Pi 5.
Portsdown 5 is being developed to work on a Raspberry Pi 4 or Raspberry Pi 5, but is not as capable as the Portsdown 4.
Outline specification
System overview
The Portsdown 4 can also be controlled from a web browser (on a PC, tablet or smartphone); full details here: Portsdown 4 Web Control.
  • BATC Filter Modulator board. DVB-S only. Portsdown 2020 only.
  • DATV Express Board (no longer available). DVB-S only. Portsdown 2020 and Portsdown 4.
  • LimeSDR (Mini or USB). DVB-S and DVB-S2. Portsdown 2020 and Portsdown 4.
  • Adalm Pluto. DVB-S and DVB-S2. Portsdown 4 only.
The Portsdown transmitter will take audio and video inputs from the RPi camera, an EasyCap composite video USB dongle, C920 webcam and a USB sound card / dongle - all these are readily available from ebay and Amazon. It will also accept an externally encoded Transport Stream from a PC or a LinkPi encoder. Note that, during transmit, live video is only shown if you are using a Pi Camera, not a webcam or EasyCap.
Portsdown DATV receiver
On Portsdown 2020 and Portsdown 4, if you plug a MiniTiuoner or a PicoTuner into the RPi USB port and select "Rx" on the top level menu, you will have access to a fully functional DVB--S/S2 DATV receiver. If used with a Knucker tuner, DVB-T transmissions can also be received.
For more details on DATV receptions see https://wiki.batc.org.uk/DVB-S/S2_Reception
Portsdown Test Equipment
The Portsdown 4 includes some very useful test equipment features including 6GHz RF signal generator, Noise figure meter, frequency sweeper and noise power meter.
See this wiki page Portsdown Test Equipment for more details.
Portsdown streamer to BATC.TV
The Portsdown can be used to stream to the BATC streamer - see https://wiki.batc.org.uk/Configuring_your_channel#Streaming_from_the_Portsdown
Meteor Viewer
The Portsdown 4 build includes the capability to view 10 kHz of spectrum from an SDRPlay RSPdx. This capability is intended to be used to view the reflections of the GB3MBA beacon from meteors. Full details here: Portsdown MeteorView.
Portsdown Hardware
Technical Index
HDMI Repeater TX Build Instructions
The Portsdown 4 can be used with an Elgato Camlink 4K HDMI capture dongle and a LimeSDR as the basis of an all-digital repeater transmitter (see CQ-TV 277). The software setup is described here Portsdown 4 HDMI Repeater TX Card Setup.
Portsdown Evolution
There are 2 supported Portsdown versions, and one version under development:
Portsdown 4
The latest version of the Portsdown is the Portsdown 4. This uses the Raspios Buster legacy operating system on a Raspberry Pi 4 with a 7 inch screen and a LimeSDR or ADALM Pluto. Unlike the previous version changes, it does not maintain hardware compatibility with the classic (filter-modulator) Portsdown.
The Portsdown 4 can transmit and receive DVB-S, DVB-S2 and DVB-T. The transmit capabity requires a LimeSDR or Pluto SDR and the receve capability requires a MiniTiouner/PicoTuner (DVB-S/S2) or Knucker Tuner (DVB-T).
New developments will be fielded in the Portsdown 4 software, and may not be back-ported to the Portsdown 2020.
Portsdown 2020 Buster
The Portsdown 2020 is Raspberry Pi 3 based running the Buster legacy operating system - Portsdown 2020. This software includes support for the LimeDVB firmware on the LimeSDR Mini and also supports the use of standard firmware on the LimeSDR USB and the LimeNET Micro.
This version will continue to be actively supported, but most new developments will be reserved for the Portsdown 4.
Portsdown 5
The Portsdown 5 has been under development since mid-2024. It is designed to use the Raspberry Pi 4 or Raspberry Pi 5, although some features may only be available on the Raspberry Pi 5. Initail details are here Portsdown 5 Introduction
Older Versions
"Portsdown 2018 Classic" was the original version was launched in 2017 - Portsdown 2018. It was based on the Raspbian Jessie operating system running on a Raspberry Pi 3 with a 3.5 inch touchscreen. It used the BATC-supplied Filter-Modulator board and could take video from the Raspberry Pi Camera or the EasyCap. It would transmit DVB-S MPEG-2 with audio, or H264 without audio. This version is no longer supported, although it will continue to work as built
"Portsdown 2019 Stretch" was the second version, using the Raspbian Stretch Operating System - Portsdown 2019. Support for the 7 inch touchscreen was added and some WebCams could also be used as a video source. Audio capability was added for H264 encoding, and early support was provided for the LimeSDR Mini. Later versions also supported the LongMynd receive software enabling good DATV reception using a MiniTiouner. Again, this version is no longer supported, although it will continue to work as built.
