Portsdown 2019
The 2019 Portsdown is significantly different to previous versions in that the system no longer uses the custom built Filter Modulator card which has been replaced with an off-the-shelf LimeSDR Mini.
Overall the LimeSDR Mini is similar in cost to the F-M board as you no longer need an ADF4351 LO module and an LO filter PCB; it is available from the BATC shop https://batc.org.uk/shop/limesdr-mini/. This guide is in a number of sections which cover detailed descriptions for hardware and software, how to build and configure the system, some advanced features and an FAQ.
Portsdown 2018
If you would still like an F-M board, we suggest you post on the wanted section of the forum - https://forum.batc.org.uk/viewforum.php?f=14 - or blank PCBs for home construction are available here - BATC shop item 10.
All the wiki information on previous version of Portsdown are available here...
Specification
The Portsdown will accept video input from a composite video source, the Pi camera, some WebCams or integrated stored test cards. It will then encode these as MPEG-2 or H264 with stereo audio.
Using a LimeSDR Mini it will transmit DATV on frequencies between 30 MHz and 3.5 GHz. Typical power output varies with frequency and is plotted here: LimeSDR_Mini_Output_Power_Levels. DVB-S and DVB-S2 modes are available from the LimeSDR Mini, with QPSK, 8PSK, 16APSK and 32APSK. Symbol rates are generally limited to 1000KS and below (down to 66 KS), but some H264 modes will work at 2MS.
Higher symbol rates (up to 5MS) are available from the Portsdown filter-modulator board, but only in DVB-S modes between 70 and 1500 MHz.
The Portsdown will also drive a DATV Express board to generate DVB-S signals from 70 MHz to 2450 MHz.
Hardware System Diagram
Building the system
Portsdown 2019 Software
Waveshare 3.5 inch screen
To get started, once you have an SD card with the Portsdown 2019 software loaded, simply put the card in the SD slot on the RPi.
If you have a Waveshare touch screen the Portsdown 2019 software is pre-configured ready to use and no initial configuration is required. Connect the Waveshare 3.5 inch touchscreen (being careful to align the pins correctly) and apply power to the RPi and the user interface should appear.
Element 14 7 inch screen
A new or upgraded SD Card (version 201902070 or later) will also work out of the box with the 7 inch screen. It will start up and reboot to load the correct drivers the first time you use it, but after that will boot directly to Menu 1.
Advanced features
Additional information
