Portsdown 2019
Portsdown 2018
Portsdown 2018 has been superseded by Portsdown 2019 but there is NO intention to discontinue support of the 2018 model. Portsdown 2019 is recommended for all new builds but if you would still like an F-M board, we suggest you post on the wanted section of the forum - https://forum.batc.org.uk/viewforum.php?f=14 - or blank PCBs for home construction are still available here - BATC shop item 10.
All the wiki information on Portsdown 2018 is still available here.
Specification
Using a LimeSDR Mini it will transmit DATV on frequencies between 30 MHz and 3.5 GHz. Typical power output varies with frequency and is plotted here: LimeSDR_Mini_Output_Power_Levels.
DVB-S and DVB-S2 modes are available from the LimeSDR Mini, with QPSK, 8PSK, 16APSK and 32APSK. Symbol rates are generally limited to 1000KS and below (down to 66 KS), but some H264 modes will work at 2MS.
Hardware System Diagram
Building the system
Portsdown 2019 Software
Once you have completed your hardware build or have bought the RPi, display and LimeSDR Mini and just "want to try it", connect up the hardware and insert an pre-programmed SD card into SD slot on the RPi.
Waveshare 3.5 inch and Element 14 7 inch touch screens
A new or upgraded SD Card (version 201902070 or later) will also work out of the box with the either screen and is ready to use with no initial configuration required. Connect the touchscreen (being very careful to align the pins on the Wavesahre correctly) and apply power to the RPi and the user interface menu 1 should appear.
Advanced features
Additional information
