DATV equipment capability
Portsdown DATV system (transmit and receive)
Portsdown 4
Portsdown system hosted on Raspberry Pi4 running xxxx OS
https://wiki.batc.org.uk/Portsdown_4
Lime Mini SDR
- Frequency coverage 30 and 3500 MHz.
- Output level with standard Lime 1.30 Firmware: 71 – 1300 MHz adjustable around +10 dBm. 2400 MHz +4 dBm, 3400 MHz -11 dBm.
- Output level with 1.30 and the LimeDVB overlay is -6dB but allows higher SRs and also has a much cleaner output spectrum.
- DVB-S and DVB-S2 (MPEG-2 and H264) only.
Pluto SDR
- Frequency coverage 70 MHz > 4100 MHz (for DATV – will work up to 6 GHz for narrowband and SigGen).
- DVB-S and DVB-S2 plus DVB-T
- Expected Output levels for DVB-S2 = 71 MHz -3 dBm. 146 MHz 0 dBm. 437 MHz +3 dBm. 1255 MHz +2 dBm. 2400 MHz 0 dBm. 3400 MHz -1 dBm.
Firmware notes:
- Requires range extension and dual core hack before use. https://wiki.analog.com/university/tools/pluto/users/customizing also https://www.ph4x.com/pluto-sdr-hack-2nd-cpu-core/
- Analog Devices firmware version V31 or V32 are OK for narrowband and DVB-T: https://github.com/analogdevicesinc/plutosdr-fw/releases/tag/v0.32
- For DVB-S and DVB-S2, specific firmware is required (F5OEO’s FIRM2101RC of 5 February 2020: https://wiki.batc.org.uk/Portsdown_4_Pluto#Suitable_Pluto_Firmware ). This also works for DVB-T.
DATVexpress hardware
- DVB - S only, frequency coverage 70 MHz to 2450 MHz. More info here https://www.datv-express.com/
- Output level approx +10 dBm over full frequency range.
Receive capability
- DVB-S and DVB-S2 (MPEG-2, H264 and H265) signals down to 125ks when Minituner Mk2 hardware with SERIT NIM plugged into USB port - tunes between 143 MHz to 2450 MHz.
- DVB-T (not DVB-T2) down to bandwidth of 125 KHz when Knucker PCB with SERIT 4762NIM plugged into USB port - tunes between 44 and 1002 MHz.
Portsdown 2020
Lime Mini SDR
- Frequency coverage 30 > 3500 MHz.
- DVB-S, DVB-S2 (MPEG-2 and H264) and DVB-T.
Receive capability
- DVB-S and DVB-S2 (MPEG-2, H264 and H265) signals down to 125ks when Minituner Mk2 with SERIT NIM plugged into USB port - tunes between 143 MHz to 2450 MHz.
- DVB-T (not DVB-T2) down to bandwidth of 125 KHz when Knucker PCB with SERIT 4762NIM plugged in to USB port - tunes between 44 and 1002 MHz.
F5OEO Pluto firmware
Firmware notes:
DATVExpress project
For more details on the DATVExpress project:
No longer available.
- Works with DATVExpress hardware, Lime SDRmini and Pluto
- Generates DVB-S, DVB-S2 and DVB-T
DATV receive hardware
MiniTiouner
DVB-S and DVB-S2 (MPEG-2, H264 and H265) signals down to 35Ks when used with F6DZP MiniTiouner PC software - tunes between 143 MHz to 2450 MHz. https://wiki.batc.org.uk/MiniTioune
Knucker
DVB-T (not DVB-T2) down to bandwidth of 125 KHz - tunes between 44 and 1002 MHz. https://wiki.batc.org.uk/Knucker
