DATV equipment capability
Revision as of 09:41, 26 February 2021 by G8GTZ (talk | contribs) (→Knucker DVB-T)
Transmit systems
Portsdown DATV system
Portsdown 4
Portsdown system hosted on Raspberry Pi4 running xxxx OS
https://wiki.batc.org.uk/Portsdown_4
Lime Mini SDR
  • Frequency coverage 30 and 3500 MHz.
  • Output level with standard Lime 1.30 Firmware: 71 – 1300 MHz adjustable around +10 dBm. 2400 MHz +4 dBm, 3400 MHz -11 dBm.
  • Output level with 1.30 and the LimeDVB overlay is -6dB but allows higher SRs and also has a much cleaner output spectrum.
  • DVB-S and DVB-S2 (MPEG-2 and H264) only.
Pluto SDR
  • Frequency coverage 70 MHz > 4100 MHz (for DATV – will work up to 6 GHz with Langstone narrowband SDR and Portsdown SigGen).
  • DVB-S and DVB-S2 plus DVB-T
  • Expected Output levels for DVB-S2 = 71 MHz -3 dBm. 146 MHz 0 dBm. 437 MHz +3 dBm. 1255 MHz +2 dBm. 2400 MHz 0 dBm. 3400 MHz -1 dBm.
Notes:
DATVexpress hardware
  • Output level approx +10 dBm over full frequency range.
Portsdown 2020
Lime Mini SDR
  • Frequency coverage 30 > 3500 MHz.
  • DVB-S, DVB-S2 (MPEG-2 and H264) and DVB-T.
F5OEO Pluto firmware
Firmware notes:
DATVExpress project
For more details on the DATVExpress project: https://www.datv-express.com/
No longer available.
  • Works with DATVExpress hardware, Lime SDRmini and Pluto
  • Generates DVB-S, DVB-S2 and DVB-T
DATV receive hardware
MiniTiouner DVB-S
There are several MiniTiouner PCBs available all based on a design by F6DZP and with similar specifications:
  • Frequency coverage 143 MHz >2450 MHz.
  • DVB-S and DVB-S2 (MPEG-2, H264 and H265) - receives signals down to 35Ks when used with F6DZP MiniTiouner PC software -
BATC MiniTiouner version 2
DATVExpress MiniTiounerExpress
REF MiniTiouner
Knucker DVB-T
  • Frequency coverage 44 > 1002 MHz
  • DVB-T (not DVB-T2) down to bandwidth of 125 KHz
DATV receive systems
Portsdown 4 Receive capability
  • DVB-S and DVB-S2 (MPEG-2, H264 and H265) signals down to 125ks when Minituner Mk2 hardware with SERIT NIM plugged into USB port - tunes between 143 MHz to 2450 MHz.
  • DVB-T (not DVB-T2) down to bandwidth of 125 KHz when Knucker PCB with SERIT 4762NIM plugged into USB port - tunes between 44 and 1002 MHz.
Portsdown 2020 recieve capability
  • DVB-S and DVB-S2 (MPEG-2, H264 and H265) signals down to 125ks when Minituner Mk2 with SERIT NIM plugged into USB port - tunes between 143 MHz to 2450 MHz.
  • DVB-T (not DVB-T2) down to bandwidth of 125 KHz when Knucker PCB with SERIT 4762NIM plugged in to USB port - tunes between 44 and 1002 MHz.
Ryde set top box and repeater receiver
