Getting Started
You're probably here because you want to know more about ATV so to help you get to grips with the basics the BATC has put together a series of "getting started" guides.
One of the aims of the BATC is to help members get on the air and to this end the club has come up with the Portsdown project which is easy enough for most people to successfully build at home.
The Portsdown is based around the popular Raspberry Pi 4 single board computer, an Adalm Pluto SDR, and controlled by a seven-inch touchscreen. Hundreds of these have been built by amateurs around the world and part of its success is down to the club prescribing the key components/design (and you sticking to them...) and following simple build instructions. Yes I know radio amateurs (me included) like to tinker and experiment but at this stage it really helps our volunteers help you. That way, if there are any problems, it's easy to offer support via the BATC forum. And if you still can't get it going bring it along to one of our Portsdown clinics which are held at most rallies the BATC attends.
But if this all sounds overwhelming there's an easy way to "get on the air" using transmitter/receiver modules - if so take a look at this page which shows you how to join in the fun on 5.6GHz for around £20.
2021 Digital ATV primer
We often get asked how do I start to receive or transmit Digital Amateur TV - below is an answer a BATC member gave to this question on the BATC forum.
Receiving DATV
The easiest way to receive DATV is to build a Ryde receiver. This is a Raspberry Pi 4 with BATC software which drives an external HDMI or composite monitor and has a MiniTiouner tuner card connected via a USB port. The Ryde tunes from 143 MHz to 2450 MHz so covers all the bands from 146 > 13cms and with a standard LNB can be used to receive Oscar 100 signals. It also can receive all the Symbol Rates (SR) or bandwidths from 33Ks (the lowest RB-TV you will find) right up to 27,500 as used on Freeview etc.
The system consists of a Pi4 and SD card plus the USB tuner card hardware which you build (no Surface Mount!) - the 4 hard to get components are from the BATC shop and the software is free to download - total cost = ~£80 depending upon the case you use.
See the Ryde wiki page and https://wiki.batc.org.uk/MiniTioune for more details.
DATV transmit
This basic system will cost ~ £250 ( less than a dual band FM rig!) and give you a full blown DATV transmit system from 50MHz up to 3.4GHz with good picture quality. There is some limitations on symbol rates - with the Lime SDRmini you can only transmit up to 1Ms . Again you will need filters and amplifiers for the band of your choice....
For more details see ttps://wiki.batc.org.uk/The_Portsdown_Transmitter
The Portsdown software includes everything you need - just make sure you have the latest Portsdown build - and plug your tuner card in to the Raspberry Pi USB port. See https://wiki.batc.org.uk/The_Portsdown_Receiver for more details.
Getting Started - the guides
Below are a series of guides which have been written by BATC members - unfortunately our hobby moves at a rapid pace so that guides written only 3 years ago are now out of date!
DATV Reception
Reduced Bandwidth TV
Video signal basics
What next?
Having read and digested all the information in these getting started guides and want to get on air, the next thing to look at is the BATC Portsdown DATV transmitter project.
