New builders are recommended to build a Portsdown 4 which, when used with a Adalm Pluto, is integrated with the Langstone Microwave transceiver software enabling an advanced multimode narrow band and DATV transceiver covering 70Mhz to 6GHz for under £350.
Outline specification
• Frequency coverage depends on the SDR used but covers 50, 71, 146 MHz, 437 MHz, 23cms, 13cms, 3.4GHz and 5.6 ATV bands when using Pluto SDR.
System overview
  • BATC Filter Modulator board - used in Portsdown 2018 classic but no longer available
  • DATV Express Board - used in Portsdown 2018 Classic but no longer available
  • LimeSDR (Mini or USB)
  • Adalm Pluto,
Audio and video inputs
The Portsdown transmitter will take audio and video inputs from the RPi camera, an EasyCap composite video USB dongle, C920 webcam and a USB sound card / dongle - all these are readily available from ebay and Amazon.
Portsdown DATV receiver
The received signal is displayed on the 7" touch screen but is also available as a UDP output on the network enabling it to be viewed on a larger PC using VLC or a similar software.
Portsdown Hardware
Technical Index
Portsdown Evolution
Portsdown 4
The latest version of the Portsdown is the Portsdown 4. This uses the Raspios Buster operating system on a Raspberry Pi 4 with a 7 inch screen and a LimeSDR or ADALM Pluto. Unlike the previous version changes, it does not maintain hardware compatibility with the classic (filter-modulator) Portsdown.
Portsdown 2020 Buster
The Portsdown 2020 is Rpi3 based running Buster operating system - Portsdown 2020. This introduces support for the LimeDVB firmware on the LimeSDR Mini and also supports the use of standard firmware on the LimeSDR USB and the LimeNET Micro.
Portsdown 2019 Stretch
