Portsdown 4
The Portsdown 4 transceiver software has been specifically designed to be used with the Raspberry Pi 4 and the official Raspberry Pi 7 inch touchscreen. It will drive a Pluto SDR or the LimeSDR and the DATV Express board (DVB-S only).
  • Raspberry Pi4 2GB model
  • 7" touch screen
  • 8, 16 or 32 GB SD card
  • Adalm Pluto or Lime SDRmini
This will give you a DVB-S2 and DVB-T DATV transmit system from 30 to 3500 MHz when using a Lime SDR and 50MHz to 4100 MHz with the Pluto.
With the addition of a MiniTiouner USB receiver [[1]], you will have a full spec DVB-S/S2 DATV transceiver.
With the addition of the Knucker USB tuner you will also have DVB-T receive capabilities.
Capabilities
The Portsdown 4 has the following transmit and receive capabilities:
  • DVB-S, DVB-S2 and DVB-T (H264 only) transmissions from a Pluto SDR connected by USB
  • DVB-S, DVB-S2 and DVB-T (MPEG-2 and H264) transmissions from a LimeSDR Mini or LimeSDR USB
  • Streaming to the BATC Streamer using the Raspberry Pi Camera or EasyCap composite video capture device as a source
When a MiniTiouner USB receiver is connected via USB:
  • Reception and display of DVB-S and DVB-S2 (MPEG-2, H264 and H265) signals
When a BATC Knucker USB tuner connected by USB:
  • Reception and display of DVB-T and DVB-T2 (MPEG-2, H264 and H265) signals
Portsdown test and alignment aids
  • Basic spectrum display of band occupancy using the "Portsdown Band Viewer" - requires a LimeSDR Mini to be connected.
Full details of the Portsdown hardware are available here.
No other models of Raspberry Pi or touchscreen are planned to be supported in the near future.
Portsdown 4 GPIO connections
Powering the Pluto
You MUST start with a fresh build of Raspios Buster Lite (NOT the older Raspbian) on an SD Card of 8 GB or greater, so you will need to rebuild any previous Langstone or Portsdown A27 card.
Pluto Capabilities
FAQ
cd /home/pi
chmod +x /home/pi/update.sh
./update.sh
  • I have built my Portsdown 4 but the screen is upside down. How can I get it the right way up?
More information
