Repeater Controller
The BATC ATV Repeater Controller uses a Raspberry Pi 4 as a fully-featured, but simple-to-implement, ATV repeater controller. The design is intended to be used with an HDMI Video switch, but can also be used with older composite video designs.
Every repeater is different and the controller is designed as a core logic that can be used as the basis for an ATV repeater. The design is flexible with a large number of parameters in a text editable config file so that users can configure it to meet their own needs.
Typical operation
Carousel
The carousel can be configured to show up to 99 scenes which are played out from the controller RPi and can be .jpg or .png images, an input on the video switcher for example mast cam, or a video file (in future release). The still images are read each time before display so can be regularly updated by an external source.
Valid signal input
Ident signal
The controller RPi also generates images for the K sequence and input identification. A video and/or audio ident can be generated at an interval set in the config file.
DTMF control
Power saving
Hardware control
  • I2C. Initial support for the Audio switch designed for GB3SQ. Details of the 8 channel input audio switch PCB can be found here: DATV repeater audio switch
Future releases may support I2C video switches and relay boards.
Configuring IR Switching
Customisation
DTMF control
The following functions can be changed using DTMF commands - the actual command sequence is entirely flexible and set in the config file.
It is recommended that some command sequences such as shut down are not publicly available and have been grouped in the example config file (see Repeater Controller configurationas keeper commands.
Suggested keeper functions
dtmfkeepertxoff
dtmfkeepertxon
dtmfkeeperreboot
dtmftalkbackaudioenable
dtmftalkbackaudiodisable
dtmfstatusview
dtmfquadview
dtmfselectinput0
dtmfselectinput1
dtmfselectinput2
dtmfselectinput3
dtmfselectinput4
dtmfselectinput5
dtmfselectinput6
dtmfselectinput7
dtmfoutputs=1
dtmfgpioout1pin=15
dtmfgpioout1label=shack_light
dtmfgpioout1on=31
dtmfgpioout1off=41
dtmfinputs=1
dtmfgpioin1pin=8
dtmfgpioin1label=cabinet_door
i2cioaddress=0
i2cdtmfoutputs=1
i2cdtmfgpioout1pin=a0
i2cdtmfgpioout1on=51
i2cdtmfgpioout1off=61
i2cdtmfinputs=1
i2cdtmfgpioin1pin=b0
GPIO Connections
Switching Logic
Project status
Feb 10th 2022 A Beta version of the software can be found here: https://github.com/BritishAmateurTelevisionClub/atv-rptr
Future requirements
  • VLC Carousel Play of videos
