Repeater Controller
Revision as of 11:47, 18 February 2022 by G8GKQ (talk | contribs) (→Hardware control)
Typical operation
Carousel
  • Video files (in future release).
  • Any input on the video switcher, so can display inputs such mast cams, weather stations or Quad video displays.
The still images are read each time before display so can be regularly updated by an external source.
Valid signal input
Ident signal
DTMF control
Power saving
Hardware control
  • Video switches via IR transmitters - up to 2 IR transmitters can be configured separately allowing multiple video switches to be cascaded.
Future releases may support I2C video switches and relay boards.
Configuring IR Switching
The IR codes for the video switches used on a repeater will need to be entered in the configuration file.
Customisation
DTMF control
GPIO Connections
The repeater controller accepts up to 8 signal detect inputs on the GPIO input pins and uses IR / I2C or GPIO outputs to control video switchers.
Switching Logic
Project status
Future requirements
Currently, we are not adding additional features until the design is proven to be stable.
  • VLC Carousel Play of videos
