Portsdown hardware
Raspberry Pi
These are available from many suppliers and we suggest you just buy a Raspberry Pi without any additional boards or SD cards as you will be using specific Portsdown hardware and software. If you are starting a new build, the Raspberry Pi 4 Model B with 2 GB of RAM is recommended (4 GB or 8 GB or RAM will work, but costs more for no performance advantage).
Power Supplies
Micro-SD Card
LCD Touchscreen
7" Touchscreen
5" Touchscreen
  1. Preset 1 (Menu 3 should then be displayed)
  2. M2 (the System Configuration Menu should then be displayed)
  3. Just above Web Control (the reboot question should then be displayed)
  4. The "d" of inverted (the system should then reboot)
After the reboot, you should again go to Menu 3, System Config and select the 5 inch screen to get a reliable response to touches.
3.5" OSOYOO DSI Touchscreen
Hubertus DC1OP has reported that the OSOYOO 3.5 Inch DSI Touchscreen LCD Display also works with the Portsdown 4 in the same way as the DFRobot 5 inch screen - it needs the touchmap to be rotated as for the 5 inch screen. This has not been tested by the development team, so purchase at your own risk!
This screen can be found on Amazon: https://www.amazon.co.uk/OSOYOO-Capacitive-Connector-Resolution-Raspberry/dp/B087WVC1J2
The key enabler is that it is a DSI-connected screen with 800x480 resolution. Note that DPI-connected, or different resolution touchscreens WILL NOT work with the Portsdown.
3.5" Waveshare Touchscreen
GPIO Extender Card
LimeSDR
Pluto SDR
Raspberry Pi Camera
If you want to transmit live pictures you will need a camera. The standard V1 or V2 Pi camera gives excellent results but will need mounting in a housing and does not have audio input.
Raspberry Pi 2 Camera: CPC Farnell https://cpc.farnell.com/raspberry-pi/rpi-8mp-camera-board/raspberry-pi-camera-board-v2/dp/SC18701
The Portsdown is only compatible with the Raspberry Pi V1, V2 and HQ cameras. It will not operate with the V3 camera or the Global Shutter Camera, as these require a later version of the operating system which does not support the video encoding features used by the Portsdown transmitter. Raspberry Pi Camera information can be found here: https://www.raspberrypi.com/documentation/accessories/camera.html#hardware-specification
Kits are available to connect a female HDMI connector to the RPi camera connector, and another female to the camera, allowing the use of domestic 1, 2 and 3m HDMI leads.The maker is Petite Studio
In the UK and most of the world it's best to get the Petite Studio kit at Pimoroni. It's called Raspberry Pi Camera HDMI Cable Extension.
WebCams
There are at least 3 similar devices being marketed under this name on eBay, each with different chipsets, but only the Fushicai "USBTV007" brand is guaranteed to work in all modes on the Portsdown 2020 and Portsdown 4. The Portsdown 4 was modified in Oct 2023 to partially support the "MS2106". The type of EasyCap can be identified by connecting it to the Portsdown 4, selecting “Menu 2”, “File Menu”, “List USB Devices”. Then refer to the table below.
Name USB Ident Compatibility Notes
Fushicai 1b71:3002 Fushicai... Portsdown 2020 and Portsdown 4 BATC Shop pre-2020
MS2106 534d:0021 Limited with Portsdown 4 only BATC Shop post-2020
Arkmicro 18ec:5555 Arkmicro.... None
Latest versions of the Portsdown 4 will work for Lime and Pluto DVB-S/S2 H264 transmission and streaming with the MS2106 EasyCap that is available from the BATC Shop (2023) https://batc.org.uk/shop/video-capture-device-not-for-use-with-portsdown/. The Chipset in this EasyCap is based on the MS2106 chip from MacroSilicon, hence the name.
The MS2106 has some limitations: The lip sync with this EasyCap is not perfect, but it has not proved possible to improve it, and it needs to be driven with a valid composite video signal otherwise the transmitter fails to start.
Audio Capture Device
The microphone connection is for a T-R-S 3.5mm jack. Be careful when buying e.g. a Lavelier Tie-pin microphone to avoid those with T-R-R-S jacks intended for mobile phone use. These do not produce any audio in the Portsdown!
RF Switching
4-Band RF Output Switch
4-Band Decode Switch
8-Band RF Output Switch
8-Band Decoder
8-Band Decode PIC
2-Way RF Switch
Not required for Portsdown 4.
Filters and PA drivers
Output Attenuator
