Portsdown hardware
Raspberry Pi
These are available from many suppliers and we suggest you just buy a Raspberry Pi without any additional boards or SD cards as you will be using specific Portsdown hardware and software. If you are starting a new build, the Raspberry Pi 4 Model B with 2 GB of RAM is recommended (4 GB or 8 GB or RAM will work, but costs more for no performance advantage).
Power Supplies
Micro-SD Card
LCD Touchscreen
7" Touchscreen
Alternative 7" Touchscreen
During 2025, 7 inch touchscreens that are reported to be compatible have become available on AliExpress for about £25. The description is generally: "7 Inch DSI Touch Screen for Raspberry Pi 5 4B 3B+ 3B IPS Display 800*480 LCD MIPI CSI Cable With Standard Monitor for RPI 5 Pi5". The key points here are that it must use a CSI or DSI cable, and must be 800*480. Be very careful buying from AliExpress - it is very easy to buy the wrong (incompatible) item!
Note that this touchscreen initially may not appear to respond to touch commands; follow the instructions below to rotate the touch overlay and you can correct this issue.
On initial build with this screen, the Portsdown touch map is rotated by 180 degrees. This can be corrected by navigating to Menu 3, System Config, Invert Touchscreen. If you can’t work out exactly where to press, here are the touch points:
- Preset 1 (Menu 3 should then be displayed)
- M2 (the System Configuration Menu should then be displayed)
- Just above Web Control (the reboot question should then be displayed)
- The "d" of inverted (the system should then reboot)
Alternatively, (after updating to sodftware version 202509170) log into the SSH Console menu, select Display and Invert.
5" Touchscreen
After the reboot, you should again go to Menu 3, System Config and select the 5 inch screen to get a reliable response to touches.
3.5" OSOYOO DSI Touchscreen
Hubertus DC1OP has reported that the OSOYOO 3.5 Inch DSI Touchscreen LCD Display also works with the Portsdown 4 in the same way as the DFRobot 5 inch screen - it needs the touchmap to be rotated as for the 5 inch screen. This has not been tested by the development team, so purchase at your own risk!
This screen can be found on Amazon: https://www.amazon.co.uk/OSOYOO-Capacitive-Connector-Resolution-Raspberry/dp/B087WVC1J2
The key enabler is that it is a DSI-connected screen with 800x480 resolution. Note that DPI-connected, or different resolution touchscreens WILL NOT work with the Portsdown.
GPIO Extender Card
LimeSDR
Pluto SDR
Raspberry Pi Camera
If you want to transmit live pictures you will need a camera. The standard V1 or V2 Pi camera gives excellent results but will need mounting in a housing and does not have audio input.
Raspberry Pi 2 Camera: CPC Farnell https://cpc.farnell.com/raspberry-pi/rpi-8mp-camera-board/raspberry-pi-camera-board-v2/dp/SC18701
The Portsdown is only compatible with the Raspberry Pi V1, V2 and HQ cameras. It will not operate with the V3 camera or the Global Shutter Camera, as these require a later version of the operating system which does not support the video encoding features used by the Portsdown transmitter. Raspberry Pi Camera information can be found here: https://www.raspberrypi.com/documentation/accessories/camera.html#hardware-specification
Kits are available to connect a female HDMI connector to the RPi camera connector, and another female to the camera, allowing the use of domestic 1, 2 and 3m HDMI leads.The maker is Petite Studio
In the UK and most of the world it's best to get the Petite Studio kit at Pimoroni. It's called Raspberry Pi Camera HDMI Cable Extension.
WebCams
There are at least 3 similar devices being marketed under this name on eBay, each with different chipsets, but only the Fushicai "USBTV007" brand is guaranteed to work in all modes on the Portsdown 2020 and Portsdown 4. The Portsdown 4 was modified in Oct 2023 to partially support the "MS2106". The type of EasyCap can be identified by connecting it to the Portsdown 4, selecting “Menu 2”, “File Menu”, “List USB Devices”. Then refer to the table below.
| Name | USB Ident | Compatibility | Notes |
| Fushicai | 1b71:3002 Fushicai... | Portsdown 2020 and Portsdown 4 | BATC Shop pre-2020 |
| MS2106 | 534d:0021 | Limited with Portsdown 4 only | BATC Shop post-2020 |
| Arkmicro | 18ec:5555 Arkmicro.... | None |
Latest versions of the Portsdown 4 will work for Lime and Pluto DVB-S/S2 H264 transmission and streaming with the MS2106 EasyCap that is available from the BATC Shop (2023) https://batc.org.uk/shop/video-capture-device-not-for-use-with-portsdown/. The Chipset in this EasyCap is based on the MS2106 chip from MacroSilicon, hence the name.
The MS2106 has some limitations: The lip sync with this EasyCap is not perfect, but it has not proved possible to improve it, and it needs to be driven with a valid composite video signal otherwise the transmitter fails to start.
Audio Capture Device
The microphone connection is for a T-R-S 3.5mm jack. Be careful when buying e.g. a Lavalier Tie-pin microphone to avoid those with T-R-R-S jacks intended for mobile phone use. These do not produce any audio in the Portsdown!
RF Switching
4-Band RF Output Switch
4-Band Decode Switch
Full details on the board including circuit etc are available here. Blank PCBs are available in the BATC shop - item 5.
8-Band RF Output Switch
Full details including parts list and schematic are available on this wiki page. Blank PCBs are available in the BATC shop - item 9.
8-Band Decoder
Full details on the board including circuit etc are available here. Blank PCBs are available in the BATC shop - item 7.
8-Band Decode PIC
2-Way RF Switch
Not required for Portsdown 4.
Filters and PA drivers
Output Attenuator
