Portsdown 2019
Portsdown 2018
Portsdown 2018 has been superseded by Portsdown 2019 but there is NO intention to discontinue support of the 2018 model. If you would still like an F-M board, we suggest you post on the wanted section of the forum - https://forum.batc.org.uk/viewforum.php?f=14 - or blank PCBs for home construction are still available here - BATC shop item 10.
All the wiki information on Portsdown 2018 is still available here.
Specification
Using a LimeSDR Mini it will transmit DATV on frequencies between 30 MHz and 3.5 GHz. Typical power output varies with frequency and is plotted here: LimeSDR_Mini_Output_Power_Levels.
DVB-S and DVB-S2 modes are available from the LimeSDR Mini, with QPSK, 8PSK, 16APSK and 32APSK. Symbol rates are generally limited to 1000KS and below (down to 66 KS), but some H264 modes will work at 2MS.
Hardware System Diagram
Building the system
- Portsdown2019 hardware Detailed description of the Portsdown 2019 hardware and a shopping list of what you need to buy and where to buy it.
- Assembling your Portsdown How to put all the hardware together - you need to read this!
- Portsdown Displays Advice on what display to use with your Portsdown transmitter.
Portsdown 2019 Software
- Portsdown 2018/2019 Stretch Software The latest and greatest software for the Portsdown and how to get a programmed SD card.
- Software capabilities and issues An up to date list is available here
- Updating your Portsdown Software How to update your Portsdown software to the latest version, with suggestions for troubleshooting updates.
To get started, once you have an SD card with the Portsdown 2019 software loaded, simply put the card in the SD slot on the RPi.
If you have a Waveshare touch screen the Portsdown 2019 software is pre-configured ready to use and no initial configuration is required. Connect the Waveshare 3.5 inch touchscreen (being careful to align the pins correctly) and apply power to the RPi and the user interface should appear.
Element 14 7 inch screen
A new or upgraded SD Card (version 201902070 or later) will also work out of the box with the 7 inch screen. It will start up and reboot to load the correct drivers the first time you use it, but after that will boot directly to Menu 1.
- Touchscreen mode How to use your Portsdown transmitter using the Touchscreen LCD only
- Console mode Use this mode to configure advanced settings such as WiFi or non-standard screens.
- Changing system setup How to change Portsdown transmitter settings when in Touchscreen mode
- QPSKRF or Ugly mode Notes on this special test mode and the limitations when using it
- Setting up the WiFi How to set up the WiFi on the RPi3 Portsdown Transmitter
Advanced features
- Lean DVB receiver How to use the integrated RTL SDR based monitoring receiver - this is NOT the Portsdown receiver
- Streaming to the BATC Streamer How to use your Portsdown transmitter as a standalone streamer
- Controlling a DATVExpress How to use a Portsdown as a user interface for DATV Express
- Use With a DTX-1 How to use your Portsdown transmitter to transmit RB-TV with a DTX-1
- Feeding Video to Portsdown from vMix How to use vMix with your Portsdown transmitter
- Analog Video Output How to use your Portsdown as an Analog PAL Video Source
- Still Capture from Composite Video Input How to capture still images from a Composite Video input.
- Hardware-only Transmit Switching How to use the Portsdown without a Touchscreen or computer.
- Portsdown Signal Generator Not available yet on Portsdown 2019
- Calibrating the TouchScreen Alignment
- FreqShow Displaying the received frequency spectrum
- How to Use the C920 Webcam with the Portsdown
- An Integrated RTL-FM Audio Receiver
Additional information
