Ryde Receiver
Project history and status
Ryde Hardware
The Ryde rxr is simple to construct and is built from a standard Raspberry Pi4 and standard MiniTiouner USB receiver hardware. Full hardware details are described on this page: Ryde Hardware.
Version 1
Version 2
IR remote control
RF input band switching
The Ryde has been designed to control the Portsdown 4 and 8 way RF switches https://wiki.batc.org.uk/8-Band_RF_Output_Switch
The RF switch should be built leaving out the MMIC stage U10 which is bypassed with a short circuit or a 1nf capacitor.
Note the Raspberry Pi4 GPIO connections are different to the Rpi 3 see this forum discussion and wiki page for more details:
https://wiki.batc.org.uk/Portsdown_4_GPIO_Connections
https://forum.batc.org.uk/viewtopic.php?t=7011&p=25317#p25317
Ryde Software
There are 2 ways to get the Ryde Software. As with Portsdown, you can buy a pre-programmed SD Card from the BATC Shop; or you can build your own card by following the instructions here: BATC GitHub Ryde Build Page. The process will be familiar to anyone who has built a Portsdown SD Card.
FAQ
