Portsdown hardware
Revision as of 09:06, 2 July 2021 by G8GTZ (talk | contribs) (G8GTZ moved page Portsdown2019 hardware to Portsdown hardware)
This section of the user guide describes all the hardware modules and interconnections required to build the Portsdown DATV system.
Raspberry Pi
The first item required is a standard Raspberry Pi - this can be a Pi 3 or Pi 4 depending upon the Portsdown version you are building. These are available from many suppliers and we suggest you just buy a Raspberry Pi 3B+ without any additional boards or SD cards as you will be using specific Portsdown hardware and software.
Power Supplies
You can power a Pi 4 via the GPIO pins but should power aRPi 3 through the Micro-USB power connector to take advantage of the input protection provided. Use a very short USB cable to your power supply as most of these cables are of very poor quality and cause significant voltage drop. If you see a "Lightning Flash" symbol at the top right of your LCD display it means that the voltage at the RPi is too low. You can measure the voltage between the GPIO connector pins 4 and 6.
Micro-SD Card
OR if you want to have a go at loading the software yourself you will need to or purchase a good quality card from another source and follow the instructions described here. (The 16GB SanDisk Ultra is recommended - DO NOT use cheap copies)
LCD TouchScreen
7" touchscreen"
Portsdown 2020 is designed to take advantage of the larger touchscreen, the Official Raspberry Pi 7" touchscreen (often referred to as a "7 inch Element 14 touchscreen"): https://cpc.farnell.com/raspberry-pi/raspberrypi-display/raspberry-pi-touchscreen-display/dp/SC13858 or https://www.element14.com/community/docs/DOC-78156/l/raspberry-pi-7-touchscreen-display Also available from Amazon: https://www.amazon.co.uk/Raspberry-Pi-7-Inch-Screen-Display/dp/B014WKCFR4
Note that if you use the 7 inch screen, you do not need to connect the 3 data leads between the screen and the RPi - only ground and +5v.
3.5" touchscreen"
The other supported touchscreen is a 3.5 inch diagonal Waveshare Raspberry Pi LCD (Model A, not Model B). Note this is NOT supported on the Portsdown 4.
GPIO Extender Card
LimeSDR Mini
The Portsdown 2019 system uses the LimeSDR Mini to provide the modulator and RF generator functions.
See this page for more details on using the LimeSDR Mini in a Portsdown 2019 system.
Pluto SDR
You now have the components for a fully working Portsdown transmitter!  See this page for suggestions on how to connect it all up.
Raspberry Pi Camera
To help make sure you buy a unit that will work with Portsdown we are now stocking the Fushicai USBTV007 Audio-Video Grabber which is guaranteed to work in the BATC shop - item 11.  More information on the device can be found here.
Audio Capture Device
Audio Capture Device:  Source from eBay - for example: http://www.ebay.co.uk/sch/Laptop-Desktop-Accessories/31530/i.html?_from=R40&_nkw=usb%20audio%20adapter&_dcat=75518&Channels=2%252E0&rt=nc&_trksid=p2045573.m1684
RF Switching
4-Band RF Output Switch
4-Band Decode Switch
8-Band RF Output Switch
8-Band Decoder
8-Band Decode PIC
2-Way RF Switch
This switch allows you to route the outputs from the Portsdown Pluto and a LimeSDR to a single PA, enabling both to be used without reconfiguration. Full details on this Wiki page 2-Way RF Switch.
Filters and PA drivers
Output Attenuator
Altough not required when using the Lime Mini or Pluto SDR, the Portsdown can use an electronically switched attenuator to adjust the transmit drive level for each band. Attenuators based on the PE4302, HMC1119 or PE43703 (preferred) are supported.
