Portsdown hardware
Raspberry Pi
The first item required is a standard Raspberry Pi - this can be a Pi 3 or Pi 4 depending upon the Portsdown version you are building. These are available from many suppliers and we suggest you just buy a Raspberry Pi 3B+ without any additional boards or SD cards as you will be using specific Portsdown hardware and software.
Power Supplies
You can power a Pi 4 via the GPIO pins but should power a RPi 3 through the Micro-USB power connector to take advantage of the input protection provided.
Use a very short USB cable to your power supply as most of these cables are of very poor quality and cause a significant voltage drop. If you see a "Lightning Flash" symbol at the top right of your LCD display it means that the voltage at the RPi is too low. You can measure the voltage between the GPIO connector pins 4 and 6.
Micro-SD Card
OR if you want to have a go at loading the software yourself you will need to or purchase a good quality card from another source and follow the instructions described here. The 16GB SanDisk Ultra is recommended - DO NOT use cheap copies.
LCD TouchScreen
7" touchscreen"
Portsdown 2020 is designed to take advantage of the larger touchscreen, the Official Raspberry Pi 7" touchscreen (often referred to as a "7 inch Element 14 touchscreen")
3.5" touchscreen"
Note this is NOT supported on the Portsdown 4. The other supported touchscreen on Portsdown 2019 is a 3.5 inch diagonal Waveshare Raspberry Pi LCD (Model A, not Model B).
GPIO Extender Card
LimeSDR Mini
The Portsdown 2019 system uses the LimeSDR Mini to provide the modulator and RF generator functions.
See this page for more details on using the LimeSDR Mini in a Portsdown 2019 system.
Pluto SDR
Raspberry Pi Camera
If you want to transmit live pictures you will need a camera. The standard Pi camera gives excellent results but will need mounting in a housing and does not have audio input.
To help make sure you buy a unit that will work with Portsdown we are now stocking the Fushicai USBTV007 Audio-Video Grabber which is guaranteed to work in the BATC shop - item 11. More information on the device can be found here.
Audio Capture Device
Audio Capture Device: Source from eBay - for example: http://www.ebay.co.uk/sch/Laptop-Desktop-Accessories/31530/i.html?_from=R40&_nkw=usb%20audio%20adapter&_dcat=75518&Channels=2%252E0&rt=nc&_trksid=p2045573.m1684
RF Switching
4-Band RF Output Switch
4-Band Decode Switch
Full details on the board including circuit etc are available here. Blank PCBs are available in the BATC shop - item 5.
8-Band RF Output Switch
Full details including parts list and schematic are available on this wiki page. Blank PCBs are available in the BATC shop - item 9.
8-Band Decoder
Full details on the board including circuit etc are available here. Blank PCBs are available in the BATC shop - item 7.
8-Band Decode PIC
2-Way RF Switch
This switch allows you to route the outputs from the Portsdown Pluto and a LimeSDR to a single PA, enabling both to be used without reconfiguration. Full details on this Wiki page 2-Way RF Switch.
Filters and PA drivers
Output Attenuator
Altough not required when using the Lime Mini or Pluto SDR, the Portsdown can use an electronically switched attenuator to adjust the transmit drive level for each band. Attenuators based on the PE4302, HMC1119 or PE43703 (preferred) are supported.
