Portsdown hardware
Raspberry Pi
The first item required is a standard Raspberry Pi - this can be a Pi 3 or Pi 4 depending upon the Portsdown version you are building. These are available from many suppliers and we suggest you just buy a Raspberry Pi without any additional boards or SD cards as you will be using specific Portsdown hardware and software. If you are starting a new build, the Raspberry Pi 4 Model B with 2 GB of RAM is recommended (4 GB or 8 GB or RAM will work, but costs more for no performance advantage).
Power Supplies
Micro-SD Card
OR if you want to have a go at loading the software yourself you will need to or purchase a good quality card from another source and follow the instructions described here. The 16GB SanDisk Ultra is recommended - DO NOT use cheap copies.
LCD TouchScreen
7" touchscreen"
Portsdown 2020 is designed to take advantage of the larger touchscreen, the Official Raspberry Pi 7" touchscreen (often referred to as a "7 inch Element 14 touchscreen")
3.5" touchscreen"
Note this is NOT supported on the Portsdown 4. The other supported touchscreen on Portsdown 2019 is a 3.5 inch diagonal Waveshare Raspberry Pi LCD (Model A, not Model B).
GPIO Extender Card
LimeSDR Mini
See this page for more details on using the LimeSDR Mini in a Portsdown 2010 system.
Pluto SDR
Raspberry Pi Camera
If you want to transmit live pictures you will need a camera. The standard Pi camera gives excellent results but will need mounting in a housing and does not have audio input.
Audio Capture Device
Audio Capture Device:  Source from eBay - for example: http://www.ebay.co.uk/sch/Laptop-Desktop-Accessories/31530/i.html?_from=R40&_nkw=usb%20audio%20adapter&_dcat=75518&Channels=2%252E0&rt=nc&_trksid=p2045573.m1684
RF Switching
4-Band RF Output Switch
4-Band Decode Switch
8-Band RF Output Switch
8-Band Decoder
8-Band Decode PIC
2-Way RF Switch
Not required for Portsdown 4.
Filters and PA drivers
Output Attenuator
