Portsdown hardware
Raspberry Pi
The first item required is a standard Raspberry Pi - this can be a Pi 3 or Pi 4 depending upon the Portsdown version you are building. These are available from many suppliers and we suggest you just buy a Raspberry Pi without any additional boards or SD cards as you will be using specific Portsdown hardware and software. If you are starting a new build, the Raspberry Pi 4 Model B with 2 GB of RAM is recommended (4 GB or 8 GB or RAM will work, but costs more for no performance advantage).
Power Supplies
Micro-SD Card
LCD TouchScreen
7" Touchscreen"
The Portsdown 4 ONLY works with the Official Raspberry Pi 7" touchscreen (often referred to as a "7 inch Element 14 touchscreen"). The Portsdown 2020 works best with this screen, but can also use the 3.5 inch screen (below).
3.5" touchscreen"
Note this is NOT supported on the Portsdown 4. The other supported touchscreen on Portsdown 2019 is a 3.5 inch diagonal Waveshare Raspberry Pi LCD (Model A, not Model B).
GPIO Extender Card
LimeSDR Mini
See this page for more details on using the LimeSDR Mini in a Portsdown system.
Pluto SDR
Raspberry Pi Camera
If you want to transmit live pictures you will need a camera. The standard Pi camera gives excellent results but will need mounting in a housing and does not have audio input.
WebCams
Audio Capture Device
Audio Capture Device: Source from eBay - for example: http://www.ebay.co.uk/sch/Laptop-Desktop-Accessories/31530/i.html?_from=R40&_nkw=usb%20audio%20adapter&_dcat=75518&Channels=2%252E0&rt=nc&_trksid=p2045573.m1684
RF Switching
4-Band RF Output Switch
4-Band Decode Switch
Full details on the board including circuit etc are available here. Blank PCBs are available in the BATC shop - item 5.
8-Band RF Output Switch
Full details including parts list and schematic are available on this wiki page. Blank PCBs are available in the BATC shop - item 9.
8-Band Decoder
Full details on the board including circuit etc are available here. Blank PCBs are available in the BATC shop - item 7.
8-Band Decode PIC
2-Way RF Switch
Not required for Portsdown 4.
Filters and PA drivers
Output Attenuator
