Repeater Controller
Revision as of 09:51, 18 February 2022 by G8GTZ (talk | contribs)
The design is intended to be used with an HDMI Video switch, but can also be used with older composite video designs.
Typical operation
The BATC repeater controller controls either a single or multiple video switchers either by InfraRed, I2C or GPIO pins. It also generates a carousel of scenes and has an on-board DTMF decoder.
Carousel
  • Any input on the video switcher, for example mast cam or Quad
  • Video file (in future release).
The still images are read each time before display so can be regularly updated by an external source.
Valid signal input
Ident signal
DTMF control
Power saving
Hardware control
  • I2C support for the Audio switch designed for GB3SQ. Details of the 8 channel input audio switch PCB can be found here: DATV repeater audio switch
Future releases may support I2C video switches and relay boards.
Configuring IR Switching
Customisation
DTMF control
GPIO Connections
Switching Logic
Project status
Feb 10th 2022 A Beta version of the software can be found here: https://github.com/BritishAmateurTelevisionClub/atv-rptr
Future requirements
  • VLC Carousel Play of videos
