Repeater Controller
Revision as of 09:56, 18 February 2022 by G8GTZ (talk | contribs) (→Power saving)
Typical operation
Carousel
  • Video files (in future release).
  • Any input on the video switcher, so can display inputs such mast cams, weather stations or Quad video displays.
The still images are read each time before display so can be regularly updated by an external source.
Valid signal input
Ident signal
DTMF control
Power saving
To enable power saving by turning the repeater transmitter off during quiet periods, a number of options are available such as only key the transmitter when in repeat mode, do not key the transmit during the night time and only enable the transmitter to display the carousel for the first 30 minutes of every hour.
Hardware control
  • I2C support for the Audio switch designed for GB3SQ. Details of the 8 channel input audio switch PCB can be found here: DATV repeater audio switch
Future releases may support I2C video switches and relay boards.
Configuring IR Switching
Customisation
DTMF control
GPIO Connections
Switching Logic
Project status
Feb 10th 2022 A Beta version of the software can be found here: https://github.com/BritishAmateurTelevisionClub/atv-rptr
Future requirements
  • VLC Carousel Play of videos
