Repeater Controller
Typical operation
Carousel
  • Video files (in future release).
  • Any input on the video switcher, so can display inputs such mast cams, weather stations or Quad video displays.
The still images are read each time before display so can be regularly updated by an external source such as weather maps, propagation maps or DXspots.
Valid signal input
On receipt of a valid GPIO line signal from, for example, a Ryde receiver, the controller will, key the transmitter, play an audio beep and display an image for .5 seconds indicating which input has been activated and then switch to that input. When the receiver closes, the logic will play a "K" image and optional "K" in Morse and go back to the carousel.
Ident signal
DTMF control
Power saving
Repeater system sample builds
Hardware control
  • Video switches via IR transmitters - up to 2 IR transmitters can be configured separately allowing multiple video switches to be cascaded.
  • i2c
i2c interface
The controller will support i2c video switches and relay boards. I2c Interface details are here: DATV Repeater i2c Interface.
i2c audio switching
The controller supports the i2c controlled Audio switch designed for GB3SQ. Details of the 8 channel input audio switch PCB can be found here: DATV repeater audio switch
Configuring IR Switching
The IR codes for the video switches used on a repeater will need to be entered in the configuration file - see Repeater Controller configuration.
IR Transmitter Control Circuits
Here are example IR transmitter control circuits for the single and dual switch cases:
Customisation and configuration
DTMF control
GPIO Connections
  • Accepts up to 8 signal detect inputs
  • IR / I2C drive output
  • GPIO outputs to control video switchers.
  • Auxilliary equipment status monitoring inputs
  • Auxilliary equipment control outputs
The exact pins used for each function are set in the configuration file.
Composite video input
In order to enable analogue receivers and equipment, such as mast cameras, to be connected to an HDMI switcher, BATC has developed a composite to HDMI converter.
Based on the Ryde software running on a Pi3 or Pi4, it uses a Fushicai EasyCap and provides a high-quality converter even with noisy FM video signals.
Build an SD card with the Ryde software and after updating to release 03/03/22 select Option 8 on the Settings Menu in the SSH Console Menu.
Then manually edit the file /home/pi/ryde-build/cv_config.txt where you can set audio out, 16:9/4:3 and the ident caption.
After rebooting with a Fushicai EasyCap connected, the HDMI output will show the Composite video input and carry the audio from the dongle.
Note This is not a Ryde facility, the Ryde build was just a convenient starting point for the software build.
Switching Logic
Project status
The software was put on full release at the end of March 2022.
Feb 15th - Feature freeze until the first release in March
Software download
The BATC controller is available for download at https://github.com/BritishAmateurTelevisionClub/atv-rptr
Please follow the instructions carefully and note the controller runs on the Buster Lite OS and not Bullseye.
Depending upon demand we may sell preprogrammed SD cards in the BATC shop.
Future requirements
Currently, we are not adding additional features until the design is proven to be stable.
  • VLC Carousel Play of videos
