Portsdown hardware
Revision as of 10:26, 16 January 2023 by G8GTZ (talk | contribs) (→Raspberry Pi)
Raspberry Pi
New builders are recommended to build a Portsdown 4 which, when used with a Adalm Pluto, is integrated with the Langstone Microwave transceiver software enabling an advanced multimode narrowband and DATV transceiver covering 70 MHz to 4 GHz for under £500. These are available from many suppliers and we suggest you just buy a Raspberry Pi without any additional boards or SD cards as you will be using specific Portsdown hardware and software. If you are starting a new build, the Raspberry Pi 4 Model B with 2 GB of RAM is recommended (4 GB or 8 GB or RAM will work, but costs more for no performance advantage).
Power Supplies
Micro-SD Card
LCD Touchscreen
7" Touchscreen
5" Touchscreen
  1. Preset 1 (Menu 3 should then be displayed)
  2. M2 (the System Configuration Menu should then be displayed)
  3. Just above Web Control (the reboot question should then be displayed)
  4. The "d" of inverted (the system should then reboot)
After the reboot, you should again go to Menu 3, System Config and select the 5 inch screen to get a reliable response to touches.
3.5" OSOYOO DSI Touchscreen
Hubertus DC1OP has reported that the OSOYOO 3.5 Inch DSI Touchscreen LCD Display also works with the Portsdown 4 in the same way as the DFRobot 5 inch screen - it needs the touchmap to be rotated as for the 5 inch screen. This has not been tested by the development team, so purchase at your own risk!
This screen can be found on Amazon: https://www.amazon.co.uk/OSOYOO-Capacitive-Connector-Resolution-Raspberry/dp/B087WVC1J2
The key enabler is that it is a DSI-connected screen with 800x480 resolution. Note that DPI-connected, or different resolution touchscreens WILL NOT work with the Portsdown.
3.5" Waveshare Touchscreen
GPIO Extender Card
LimeSDR
Pluto SDR
Raspberry Pi Camera
If you want to transmit live pictures you will need a camera. The standard Pi camera gives excellent results but will need mounting in a housing and does not have audio input.
Kits are available to connect a female HDMI connector to the RPi camera connector, and another female to the camera, allowing the use of domestic 1, 2 and 3m HDMI leads.The maker is Petite Studio
In the UK and most of the world it's best to get the Petite Studio kit at Pimoroni. It's called Raspberry Pi Camera HDMI Cable Extension.
WebCams
Audio Capture Device
RF Switching
4-Band RF Output Switch
4-Band Decode Switch
8-Band RF Output Switch
8-Band Decoder
8-Band Decode PIC
2-Way RF Switch
Not required for Portsdown 4.
Filters and PA drivers
Output Attenuator
