Portsdown 2018
Revision as of 16:16, 17 June 2020 by G8GTZ (talk | contribs)
The Portsdown 2018 DATV system has been designed to provide an easy way to “get on air” with Digital ATV at a relatively low cost, covering all of the commonly used modes, thus enabling it to be used not only on ATV repeaters but also for RB-TV Dx working.
The filter modulator card and DATVExpress card described on these pages are no longer available and new builders should follow the Portsdown 2020 build instructions here.
At end of 2018 the decision was taken not to get any more FM boards assembled as demand had dropped significantly and as we had to buy a minimum quantity of 60 we risked losing a lot of members money - all this was posted on the forum back in November and in CQ-TV 262 https://forum.batc.org.uk/viewtopic.php?f=88&t=5760.
Please note there is NO intention to discontinue support of the 2018 system. Portsdown 2020 is recommended for all new builds but if you would still like an F-M board, we suggest you post on the wanted section of the forum - https://forum.batc.org.uk/viewforum.php?f=14 - or blank PCBs for home construction are still available here - BATC shop item 10.
Portsdown 2018 User guide
This user guide is in a number of sections which cover detailed descriptions for hardware and software, how to build and configure the system, some advanced features and an FAQ.
This old index page covers most of the Portsdown 2018 features: The Portsdown Transmitter index
System specification
Building the system
Portsdown Software
The software has recently undergone a major update. If you are building a new system, or upgrading one built since March 2018, please refer to the Portsdown 2018 Stretch software guide. The original Portsdown (Jessie) software has also been upgraded to Portsdown 2018 standard.
Configuring and controlling the system
The Portsdown software is now pre-configured to use the Waveshare touchscreen. If you are using this screen, no initial set-up is required.
For advanced set-up, or if you do not have a Waveshare touchscreen, See this guide: Initial setup 2019
You can control the Portsdown transmitter in one of 2 modes: by the use of the touchscreen or through the console using a second computer.
  • Console mode Use this mode to configure your Portsdown and change pre-set configs (such as SR and Freq) used in touch screen buttons.
Advanced features
The Portsdown is not just a DATV transmitter but has several advanced features which are or may be available in the future:
Additional information
An index of all Portsdown pages
You may also find this index of TLAs useful when reading the manual!
Portsdown transmitter FAQ
And of course we need an FAQ page for those people who don't read the manual!
