Ryde Receiver
Project history and status
Ryde Hardware
The Ryde receiver is simple to construct and is built from a standard Raspberry Pi 4 and standard MiniTiouner USB receiver hardware. Full hardware details are described on this page: Ryde Hardware.
Version 1
The above shows the four of the main parts of the Ryde Version 1:-
1. Raspberry Pi 4
2. GPIO breakout PCB
4. Switch and IR sensor PCB
All parts are mounted in a Eddystone 26827PSLA Diecast box (Farnell Ordercode 301589) with room for future expansion. The BATC MiniTiouner is mounted in a separate box connected by USB to the Raspberry Pi.
Version 2
IR remote control
RF input band switching
The Ryde has been designed to control the Portsdown 4 and 8 way RF switches https://wiki.batc.org.uk/8-Band_RF_Output_Switch The RF switch should be built leaving out the MMIC stage U10 which is bypassed with a short circuit or a 1nf capacitor.
GPIO connection
Ryde Software
There are 2 ways to get the Ryde Software. As with Portsdown, you can buy a pre-programmed SD Card from the BATC Shop; or you can build your own card by following the instructions here: BATC GitHub Ryde Build Page. The process will be familiar to anyone who has built a Portsdown SD Card.
FAQ
