Portsdown 2019
Revision as of 16:20, 17 June 2020 by G8GTZ (talk | contribs)
The Portsdown 2019 DATV system has been designed to provide an easy way to “get on air” with Digital ATV at a relatively low cost, covering all of the commonly used modes, thus enabling it to be used not only on ATV repeaters but also for RB-TV DX working. Although still supported, the Portsdown 2019 system is no longer under active development. The Portsdown 2020 system provides some better features, at the expense of some older features which are no longer supported; full details here Portsdown 2020.
Specification
The Portsdown 2019 will accept video input from a composite video source, the Pi camera, some WebCams or integrated stored test cards. It will then encode these as MPEG-2 or H264 with stereo audio. Note that video sources must be connected during boot-up.
  • Frequency range - Using a LimeSDR Mini it will transmit DATV on frequencies between 30 MHz and 3.5 GHz.
  • Power output - Typical power output varies with frequency and is plotted here: LimeSDR_Mini_Output_Power_Levels. The power output level can be increased and leveled off the frequency range by using a Portsdown 8 way RF switch on the output.
  • Transmission modes - DVB-S and DVB-S2 modes are available from the LimeSDR Mini, with QPSK, 8PSK, 16APSK and 32APSK.
  • Symbol rate - Due to the limited processing power and USB capability of the RPi, symbol rates are generally limited to 1MS and below (down to 66 KS), but some H264 modes will work at 2MS. Note the LimeSDR Mini hardware is capable of higher symbol rates when used with DATV Express software.
Hardware System Diagram
Building the system
Portsdown 2019 Software
Once you have completed your hardware build or have bought the RPi, display and LimeSDR Mini and just "want to try it", connect up the hardware and insert an pre-programmed SD card into SD slot on the RPi.
Waveshare 3.5 inch and Official Raspberry Pi 7" screens
A new or upgraded SD Card (version 201902070 or later) will also work out of the box with the either screen and is ready to use with no initial configuration required. Connect the touchscreen (being very careful to align the pins on the Wavesahre correctly) and apply power to the RPi and the user interface menu 1 should appear.
If you do not have a Waveshare 3.5 inch screen or the Official Raspberry Pi 7" screen, or you wish to enter the system advanced set-up pages you will need to do an initial setup - see this guide for more details: Initial setup 2019
LimeSDR Configuration
The latest Portsdown software (201903250 and beyond) requires that all LimeSDR Minis purchased from the BATC Shop before 31 March 2019 be upgraded to Firmware Version 6, Gateware Version 1, revision 29. You can do this from the Portsdown Menu 3, Lime Config, Update Lime FW. You can then check the upgrade using the "Lime FW Info" button. Note that you need to be connected to the internet during the update, otherwise it will fail. LimeSDR USBs can be upgraded using the same procedure to Firmware Version 4, Gateware 2.20. However, note that the Lime Report will fail for a LimeSDR USB, as it checks for a LimeSDR Mini.
The Lime configuration options are described here: Using_LimeSDR_with_Portsdown.
Using Portsdown with a LimeNET Micro
The Portsdown software is being modified to support the use of a LimeNET Micro as a secondary alternative to the LimeSDR Mini. These modifications are in software update 201907070 and are described here: Portsdown with the LimeNET Micro.
Advanced features
Additional information
