Ryde Receiver
Revision as of 11:36, 21 March 2024 by G8GTZ (talk | contribs) (→‎Ryde Hardware)
It is controlled by an IR remote and has a "point and shoot" interface - simply enter frequency and SR and the Ryde will look for DVB-S or DVB-S2 DATV signals without the need to enter Bouquets, transponders or scan across a range of frequencies. It will also receive DVB-T signals when used with a Knucker tuner.
Ryde Hardware
The Ryde receiver is simple to construct and is built from a standard Raspberry Pi 4 and either MiniTiouner USB receiver hardware for DVB-S2 reception or Knucker hardware connected via USB. .
The above shows the four of the main parts of the Ryde:-
1. Raspberry Pi 4
2. GPIO breakout PCB
4. Switch and IR sensor PCB
All parts are mounted in a Eddystone 26827PSLA Diecast box (Farnell Ordercode 301589) with room for future expansion.
The BATC MiniTiouner or Knucker tuner are mounted in a separate box connected by USB to the Raspberry Pi.
IR remote control
RF input band switching
The Ryde has been designed to control the Portsdown 4 and 8 way RF switches https://wiki.batc.org.uk/8-Band_RF_Output_Switch The RF switch should be built leaving out the MMIC stage U1 which is bypassed with a short circuit or a 1nf capacitor.
This switching is enabled in Ryde software version 202111051 and later. The default GPIO pins are specified in the Ryde_GPIO_Connections, but can be changed by manually editing the /home/pi/ryde/config.yaml file. Note that the numbers in the config file refer to the Broadcom port numbers in the second column of the GPIO table.
GPIO connection
Ryde Software
There are 2 ways to get the Ryde Software. As with Portsdown, you can buy a pre-programmed SD Card from the BATC Shop; or you can build your own card.
Building Your Own SD Card
The instructions on this page BATC GitHub Ryde Build Page (scroll down) take you step-by-step through building your own Ryde SD Card. No great computer expertise is required. The process will be familiar to anyone who has built a Portsdown SD Card.
Ryde presets
You can also manually edit the presets as described here Ryde_Software#Manually_Editing_the_Presets.
Ryde scanning modes
  • Log in via SSH
  • For a repeater go to menu 2 and define which preset to use on start up.
  • Then go to menu 4 and customise your preset - enter frequency (or frequencies) followed by up to 4 symbol rates. Restart your Ryde and it will use the start up preset and scan Frequencies and Symbol rates as entered.
Customising the Ryde
You change what information is displaed on the screen - details in this forum post: https://forum.batc.org.uk/viewtopic.php?f=130&t=7502&hilit=customising+ryde
You change the words on the Red splash screens - details here: https://forum.batc.org.uk/viewtopic.php?f=130&t=8054
As well as a dedicated shack receiver without the need for a PC, the Ryde is also designed for use at repeater sites.
The Ryde as a DVB-T Receiver
The Ryde is also capable of receiving DVB-T signals in conjunction with the Knucker receiver.
In the config file, the DVB-T tuner must be selected when the band is defined. The default config file has 2 DVB-T channels, 146.5 MHz, 333 kHz bandwidth and 437 MHz 333 kHz bandwidth.
The Ryde DVB-S/S2 Watchdog
The Ryde is perfect for use at Exhibitions to the public, but sometimes when auto-tuning on QO-100 it will come across a station with illegal parameters and crash. The Ryde watchdog, described here Ryde Watchdog restarts the Ryde application when this happens.
FAQ
