BATC Wiki
Revision as of 12:49, 21 June 2019 by M0DNY (talk | contribs)
Welcome to the British Amateur Television Club Wiki - the place to find information on on all Amateur Television related equipment and projects.
This is a reference library - please use the BATC forum for discussion on these or any other items.
This is your site, developed by the BATC for use by the worldwide ATV community - any information which you feel is of use to others can be put on the Wiki but please observe any copyright restrictions on your material you use. However, before you can add or edit content you will need to register for an account.
Contents
New to Amateur TV?
BATC Information and services
CQ-TV Magazine
BATC Event Streaming Equipment
BATC Conventions
  • CAT 18 Presentations and links to the videos from the 2018 convention.
  • CAT 17 Antenna test range results, presentations and links to the videos from the 2017 convention.
  • CAT 16 Presentations and links to the videos from the 2016 convention.
  • Video Recordings from previous ATV Conventions can be found on the BATC YouTube Channel.
International Events
Getting on the air with ATV
The ATV bands
The different ATV modes
Equipment Options
Using production software for ATV
Operating
ATV repeaters
Es'hail-2
ATV construction projects
  • The Portsdown Transmitter - the BATC's Raspberry Pi-based DATV Transmitter
  • MiniTioune - the DATV USB receiver project
  • Receiver upconverters - Details of upconverters to receive 146 and 437 MHz on STB and MiniTioune
  • Jetson Nano - Third generation computer-based DATV Transmitter
  • Digilite - The original home build DATV construction project
  • DigiThin - plug in QPSK modulator module for Rpi
  • DTX1 TS - interface board to take in TS streams to the DTX1
  • RpiDATV - software for the Rpi
  • RBTVMOD - variable rate RB-TV mdulator for the Rpi
  • DATVExpress - SDR hardware based DATV transmitter covering 70 - 2450 MHz
  • RPi Test Card - Raspberry Pi based Animated Test Card Generator
  • PE4302 - PE4302 variable attenuator project
  • ADF435x PIC - PIC controllers for Chinese ADF4350/4351 boards
  • DigiTwist - an experimental 2 axis satellite tracker
Useful Circuits and notes
ATV Equipment manuals and schematics
Ex commercial broadcast equipment manuals
Test equipment manuals
For HP and Agilent equipment see the Yahoo group
Other equipment information related to ATV
